Ir para o conteúdo principal
DigiLand DL701Q Back Case Replacement
O que você precisa
  1. DigiLand DL701Q Back Case Replacement, Back Case: passo 1, imagem 1 %32 DigiLand DL701Q Back Case Replacement, Back Case: passo 1, imagem 2 %32 DigiLand DL701Q Back Case Replacement, Back Case: passo 1, imagem 3 %32
    • Make sure your device is turned off.
    • Hold the device firmly, in landscape view.
    • Locate the crevice that separates the front cover from the back cover. Then hold the plastic opening tool and insert the wedge portion of the tool into the crevice.
    • Some force may need to be applied and there may be a cracking sound. This is normal.
    • Slowly slide the wedge portion of the plastic opening tool while applying some upward force around the device until the back cover is completely loose.
    • Only apply enough force to loosen the back cover. Excessive force may damage the screen.
  2. DigiLand DL701Q Back Case Replacement: passo 2, imagem 1 %32 DigiLand DL701Q Back Case Replacement: passo 2, imagem 2 %32 DigiLand DL701Q Back Case Replacement: passo 2, imagem 3 %32
    • Place the screen in the palm of your hand and then with your other hand carefully grab the case and remove the cover like flipping the page of a book.
    • Lay the device down and notice that the speaker will be attached to the back cover with a wire. Carefully lift the speaker upward from the back cover and place it near the battery.
    • The speaker may be glued in so treat with care and remove the speaker by gently moving your finger around it and lifting up.
Conclusão
Uma outra pessoa concluiu este guia.
Jonathan Mysona
Membro desde: 03/21/16
1.117 Reputação
7 Guias de autoria
Equipe
Clemson, Team 6-1, Benson Spring 2016 Membro de Clemson, Team 6-1, Benson Spring 2016
CLEM-BENSON-S16S6G1
3 Membros
7 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 6
Duração total: 826
