Ir para o conteúdo principal
DigiLand DL701Q Back Case Replacement
O que você precisa
  1. DigiLand DL701Q Back Case Replacement, Back Case: passo 1, imagem 1 %32 DigiLand DL701Q Back Case Replacement, Back Case: passo 1, imagem 2 %32 DigiLand DL701Q Back Case Replacement, Back Case: passo 1, imagem 3 %32
    • Make sure your device is turned off.
    • Hold the device firmly, in landscape view.
    • Locate the crevice that separates the front cover from the back cover. Then hold the plastic opening tool and insert the wedge portion of the tool into the crevice.
    • Some force may need to be applied and there may be a cracking sound. This is normal.
    • Slowly slide the wedge portion of the plastic opening tool while applying some upward force around the device until the back cover is completely loose.
    • Only apply enough force to loosen the back cover. Excessive force may damage the screen.
  2. DigiLand DL701Q Back Case Replacement: passo 2, imagem 1 %32 DigiLand DL701Q Back Case Replacement: passo 2, imagem 2 %32 DigiLand DL701Q Back Case Replacement: passo 2, imagem 3 %32
    • Place the screen in the palm of your hand and then with your other hand carefully grab the case and remove the cover like flipping the page of a book.
    • Lay the device down and notice that the speaker will be attached to the back cover with a wire. Carefully lift the speaker upward from the back cover and place it near the battery.
    • The speaker may be glued in so treat with care and remove the speaker by gently moving your finger around it and lifting up.
Conclusão
Jonathan Mysona
Membro desde: 03/21/16
1.135 Reputação
Autoria de 7 guias
Equipe
Clemson, Team 6-1, Benson Spring 2016 Membro de Clemson, Team 6-1, Benson Spring 2016
CLEM-BENSON-S16S6G1
3 Membros
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 28
Ao todo: 1,071
