Ir para o conteúdo principal
DigiLand DL1010Q Rear Case Replacement
O que você precisa
  1. DigiLand DL1010Q Rear Case Replacement, Rear Case: passo 1, imagem 1 %32
    • With a J00 Philips head screwdriver, unscrew the two 4mm black screws located at the bottom of the device.
    • Before disassembling your device, be sure it is powered off.
  2. DigiLand DL1010Q Rear Case Replacement: passo 2, imagem 1 %32 DigiLand DL1010Q Rear Case Replacement: passo 2, imagem 2 %32
    • Using a plastic opening tool, begin softly prying open device by first inserting it in between the front and back panels.
    • Continue prying the edges while moving around the device's perimeter until the back can be easily removed.
  3. DigiLand DL1010Q Rear Case Replacement: passo 3, imagem 1 %32
    • Carefully lift back panel away from the body of the device.
    • Speaker wires are connected to both the front and back panel.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 510
