Ir para o conteúdo principal
DigiLand DL1010Q Motherboard Replacement
O que você precisa
  1. DigiLand DL1010Q Motherboard Replacement, Rear Case: passo 1, imagem 1 %32
    • With a J00 Philips head screwdriver, unscrew the two 4mm black screws located at the bottom of the device.
    • Before disassembling your device, be sure it is powered off.
  2. DigiLand DL1010Q Motherboard Replacement: passo 2, imagem 1 %32 DigiLand DL1010Q Motherboard Replacement: passo 2, imagem 2 %32
    • Using a plastic opening tool, begin softly prying open device by first inserting it in between the front and back panels.
    • Continue prying the edges while moving around the device's perimeter until the back can be easily removed.
  3. DigiLand DL1010Q Motherboard Replacement: passo 3, imagem 1 %32
    • Carefully lift back panel away from the body of the device.
    • Speaker wires are connected to both the front and back panel.
  4. DigiLand DL1010Q Motherboard Replacement, Motherboard: passo 4, imagem 1 %32
    • Using a plastic opening tool, gently pry up the three Zero Insertion Force Connectors (ZIF)
  5. DigiLand DL1010Q Motherboard Replacement: passo 5, imagem 1 %32 DigiLand DL1010Q Motherboard Replacement: passo 5, imagem 2 %32
    • Using a Soldering station, desolder all 9 wires connected to the motherboard.
    • Start with the red and black positive and negative wires connected to the battery (2 wires).
    • Then move to the yellow and red twisted wires and black and red twisted wires connected to the speakers (4 wires).
    • Now desolder the single grey wire connected to the antenna (1 wire).
    • Lastly remove the black and red wires connected to the microphone (2 wires).
  6. DigiLand DL1010Q Motherboard Replacement: passo 6, imagem 1 %32
    • Using a J00 Philips screwdriver, unscrew the three black 4mm screws from the motherboard.
  7. DigiLand DL1010Q Motherboard Replacement: passo 7, imagem 1 %32 DigiLand DL1010Q Motherboard Replacement: passo 7, imagem 2 %32
    • Carefully lift motherboard in a upward motion.
Conclusão
2 comentários
How can I remove the CMOS battery?
solomon A.O - Responder
I NEED dl1010q MOTHER BOARD
myukimages - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 5
Duração total: 1,073
