Introdução
In this guide you should be able to:
- Proficiently remove the front and back cameras
- Locate and understand how to detach a ZIF Connector
O que você precisa
With a J00 Philips head screwdriver, unscrew the two 4mm black screws located at the bottom of the device.
Ferramenta utilizada neste passo:Tweezers$4.99
Begin by grabbing the tweezers and locating the ZIF ( zero Insertion Force) connector.
Conclusão
Uma outra pessoa concluiu este guia.
