Ir para o conteúdo principal
DigMedia MusicStore Hard Drive Replacement
O que você precisa
  1. DigMedia MusicStore Hard Drive Replacement, Remove screws: passo 1, imagem 1 %32
    • Remove six Philips #2 screws from the bottom of the case.
    • REASSEMBLY CAUTION: To prevent thread stripping during reassembly, turn screws backwards slowly until you feel the screw thread drop into the original plastic thread, and only then, tighten screw normally but lightly - you're working with 20+ year-old plastics.
  2. DigMedia MusicStore Hard Drive Replacement, Disconnect top cover ribbon cable: passo 2, imagem 1 %32
    • Carefully fold the top and bottom open, revealing a ribbon cable connecting the two halves.
    • Unlock and disconnect the ribbon cable. Unlock by pulling the lock lever evenly on both sides, parallel to the board surface (not lift/pivot), in the direction of the ribbon cable.
    • When this ZIF (Zero Insertion Force) connector is properly unlocked, the ribbon cable should just fall right out of the socket (no need to pull with any strength).
  3. DigMedia MusicStore Hard Drive Replacement, Remove RF shield: passo 3, imagem 1 %32 DigMedia MusicStore Hard Drive Replacement, Remove RF shield: passo 3, imagem 2 %32
    • Simply lift the RF shield off the unit.
    • When reinstalling, take note of the 6 fork-like interlocking clips around the edge of the shield, which should engage with the original positions.
  4. DigMedia MusicStore Hard Drive Replacement, CD-ROM cables and screws: passo 4, imagem 1 %32
    • Disconnect the digital audio connector (red) and the lid switch return connector (blue) from the logic board.
    • Unscrew four Philips #2 screws that secure the CD-ROM drive to the chassis.
  5. DigMedia MusicStore Hard Drive Replacement, Data and Power cables: passo 5, imagem 1 %32
    • Disconnect the large 40-pin IDE data connector and disconnect the 4-pin PC power connector from the CD-ROM drive.
  6. DigMedia MusicStore Hard Drive Replacement, Remove CD-ROM: passo 6, imagem 1 %32
    • Lift the CD-ROM drive out of the chassis.
  7. DigMedia MusicStore Hard Drive Replacement, Logic Board Screws: passo 7, imagem 1 %32
    • Remove 5 Philips #2 screws from the logic board (note: these are shorter than the previous screws)
  8. DigMedia MusicStore Hard Drive Replacement, Lid switch: passo 8, imagem 1 %32
    • Unplug the lid switch from the logic board. If the housing comes up with the connector (leaving only pins behind on the board), carefully separate the housing from the connector the two and push the housing back onto the pins in the original orientation.
  9. DigMedia MusicStore Hard Drive Replacement, Logic Board: passo 9, imagem 1 %32
    • Remove the logic board from the chassis.
  10. DigMedia MusicStore Hard Drive Replacement, Hard Drive Screws: passo 10, imagem 1 %32
    • Remove the two M3 Philips #2 screws from the logic board that secure the hard drive.
  11. DigMedia MusicStore Hard Drive Replacement, Hard Drive: passo 11, imagem 1 %32
    • Slide the hard drive out of its 44-pin connector, and remove the drive from the board.
    • CAUTION: When reinstalling the drive, pay close attention to the pin alignment with the socket. It's easy to miss a row of pins in either direction with this style of IDE connector.
Conclusão
Matt Falcon
Membro desde: 05/09/15
2.231 Reputação
Autoria de 13 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 83
