Ir para o conteúdo principal
How to identify fake DualShock 4 controller
O que você precisa
  1. How to identify fake DualShock 4 controller, Comparing controllers: passo 1, imagem 1 %32 How to identify fake DualShock 4 controller, Comparing controllers: passo 1, imagem 2 %32
    • The black controller is an original Sony V2. The silver one is fake. The front housing looks good so far.
    • I'm showing in picture 2 only the fake one. The tiny letters XF.LIN behind the battery capacity cannot be found on the original. Same for the letters "DW" in front of the serial code. Everything else looks the same like the original.
  2. How to identify fake DualShock 4 controller, The Screws: passo 2, imagem 1 %32 How to identify fake DualShock 4 controller, The Screws: passo 2, imagem 2 %32 How to identify fake DualShock 4 controller, The Screws: passo 2, imagem 3 %32
    • The first picture is the original. It has the original PH00 screws installed.
    • The 2nd picture displays the fake one. They used PH1 screws for this one.
    • And as you can see in the 3rd picture, the fake ones are way shorter then the original screws.
  3. How to identify fake DualShock 4 controller, The light: passo 3, imagem 1 %32
    • When the controller is searching for the PS4, it should give a bright white light, not turquoise! It's obvious that the LED/Micro USB board is fake.
  4. How to identify fake DualShock 4 controller, Battery and LED/USB board: passo 4, imagem 1 %32 How to identify fake DualShock 4 controller, Battery and LED/USB board: passo 4, imagem 2 %32 How to identify fake DualShock 4 controller, Battery and LED/USB board: passo 4, imagem 3 %32
    • Now I'll open the controller and show some more fake parts! The battery is not even close to the original one. And it's an 600mAh battery. The original delivers 800mAh. Also the fake one was telling that there was an 800mAh battery in...
    • The 2nd picture shows the original battery. Quite a difference.
    • The 3rd picture shows the LED/Micro USB board. It's obvious fake. I do not have an picture of the original one this time. There also should be text on it like (example): JDM-011 or JDM-030. There is nothing on it here. And the text colour should be in gold not in white. You can also see the fake screw holding it together again.
  5. How to identify fake DualShock 4 controller, Motherboard: passo 5, imagem 1 %32 How to identify fake DualShock 4 controller, Motherboard: passo 5, imagem 2 %32 How to identify fake DualShock 4 controller, Motherboard: passo 5, imagem 3 %32
    • In the 1st picture, you can clearly see a switch. The button should not be blue, but it should be white/grey.
    • You should see a motherboard name, like: JDM-040 or JDM-055. This indicated again that it's a fake.
    • 3rd picture shows the fake motherboard again (back side).
Conclusão
That’s it actually. There are more stuff to recognize if it’s a fake or not, but for what I’ve shown, those are the biggest differences between them.
112 outras pessoas executaram este guia.
koppie007
Membro desde: 08/22/13
12.234 Reputação
Autoria de 9 guias
Equipe
Protectors Of The Game Systems Membro de Protectors Of The Game Systems
Community
Membros da 4
Autoria de 25 guias
140 comentários
The important questions:
1. Is the fake controller able to wake up the console from sleep?
2. Does the fake controller work in all games and apps? The buttons or sticks do not feeling identical are okay, e.g. unstable analog controls are not okay.
mikko.rantalainen - Responder
1. Sometimes no. It depends on the fake (there are many different fakes), but some of them are not able to wake up the console from sleep.
2. It should work in every app and game, but due the soldered on thumb sticks (they do not use the original ones) they do not respond every time or feeling identical. Some fakes uses a totally different input board which is causing that it’s unresponsive and/or not feeling identical to the original.
koppie007 -
But how do you know if the casing is fake?
So far I have bought 1 fake controller and also found out that the plastic where the motherboard is on also is fake as you can't use original motherboard on that plastic as there seems to be some bad measures to the plastic part. Witch make the pad get stuck when closing.
Dani - Responder
Hi!
It can be very hard to see it from the outside. Did it came with the original battery or a fake on too? You need to modify the plastic part, otherwise it won’t fit I’m afraid..
koppie007 -
1. Do original DUALSHOCK 4 (CUH - ZCT2) series controller's serial numbers start with a special number? For example the DUALSHOCK first version starts with 1 and second version starts with 2. One of the serial number starts with 3911 and the other with 1911. Will I be able to check anywhere whether the serial numbers belong to original series or not?
2. Without opening both my controllers, everything matches with the original ones as per your findings above. However the L3 and R3 buttons function on their own and doesn't let me control the player and camera angle fully. The controllers have never been dropped or any physical damage caused.
Darshan Thykandy - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 310
Últimos 7 dias: 2,189
Últimos 30 dias: 10,525
Duração total: 596,119
