Ir para o conteúdo principal
Dexter wire angle grinder 800W - 800AG2-125.5 Switch Replacement
O que você precisa
  1. Dexter wire angle grinder 800W - 800AG2-125.5 Switch Replacement, Unplug: passo 1, imagem 1 %32
    • Before starting, remember to disconnect the outlet from the mains.
  2. Dexter wire angle grinder 800W - 800AG2-125.5 Switch Replacement: passo 2, imagem 1 %32 Dexter wire angle grinder 800W - 800AG2-125.5 Switch Replacement: passo 2, imagem 2 %32
    • Remove the side handle and the protective cover.
  3. Dexter wire angle grinder 800W - 800AG2-125.5 Switch Replacement: passo 3, imagem 1 %32 Dexter wire angle grinder 800W - 800AG2-125.5 Switch Replacement: passo 3, imagem 2 %32
    • Unscrew the 4 screws to open the machine.
  4. Dexter wire angle grinder 800W - 800AG2-125.5 Switch Replacement: passo 4, imagem 1 %32 Dexter wire angle grinder 800W - 800AG2-125.5 Switch Replacement: passo 4, imagem 2 %32
    • Remove the switch from his housing in order to have access to it.
  5. Dexter wire angle grinder 800W - 800AG2-125.5 Switch Replacement: passo 5, imagem 1 %32 Dexter wire angle grinder 800W - 800AG2-125.5 Switch Replacement: passo 5, imagem 2 %32
    • Unscrew the two screws.
  6. Dexter wire angle grinder 800W - 800AG2-125.5 Switch Replacement: passo 6, imagem 1 %32 Dexter wire angle grinder 800W - 800AG2-125.5 Switch Replacement: passo 6, imagem 2 %32 Dexter wire angle grinder 800W - 800AG2-125.5 Switch Replacement: passo 6, imagem 3 %32
    • Replace the component.
    • Tighten the screws well after putting the cables back on.
  7. Dexter wire angle grinder 800W - 800AG2-125.5 Switch Replacement: passo 7, imagem 1 %32
    • Before closing, check that no cables are blocked.
    • Screw the 4 screws to close.
  8. Dexter wire angle grinder 800W - 800AG2-125.5 Switch Replacement: passo 8, imagem 1 %32 Dexter wire angle grinder 800W - 800AG2-125.5 Switch Replacement: passo 8, imagem 2 %32
    • Replace the external flange, the protective cover and the side handle.
Linha de Chegada
Um agradecimento especial a esses tradutores:
fr en
100%
HelloMacOS está nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
Céline Chemineau
Membro desde: 01/29/20
16.581 Reputação
Autoria de 95 guias
Equipe
Leroy Merlin Membro de Leroy Merlin
Community
Membros da 36
Autoria de 239 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 11
Duração total: 195
