Ir para o conteúdo principal
Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement
O que você precisa
  1. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement, Unplug: passo 1, imagem 1 %32
    • Before you start, remember to disconnect the outlet from the mains.
  2. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: passo 2, imagem 1 %32 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: passo 2, imagem 2 %32
    • Remove the dust box and the seal on the back of the device.
  3. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: passo 3, imagem 1 %32 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: passo 3, imagem 2 %32 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: passo 3, imagem 3 %32
    • Unscrew the six screws of the pad.
    • Lock the motor with a screwdriver to be able to unscrew the centre screw, you will not be able to get there without blocking the gear.
  4. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: passo 4, imagem 1 %32 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: passo 4, imagem 2 %32
    • Using a screwdriver or screwdriver, unscrew and open the device.
    • Lift the two carbons with a screwdriver to get them out of their homes.
    • Remove the rotor from its housing.
    • Press the tab to disconnect the coal from the engine.
    • Unscrew the domino screws to disconnect the cables.
    • Use a clamp to extract the cables.
  5. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: passo 9, imagem 1 %32
    • Separate the wire connected to the motor.
    • Cut the rat cable with a cutting pliers.
  6. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: passo 11, imagem 1 %32 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: passo 11, imagem 2 %32
    • Unsolder the cable connected to the speed dimmer.
    • Approach the soldering iron to heat the tin and make it soft. Using the pump, remove the residues.
  7. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: passo 13, imagem 1 %32
    • Take out the old engine to replace it with the new one.
  8. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: passo 14, imagem 1 %32 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: passo 14, imagem 2 %32 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: passo 14, imagem 3 %32
    • Replace the cable of the new motor on the speed dimmer.
    • You must take the shortest cable.
    • With tin, unsolder the wire on the frame to hold it.
    • Replace the speed dimmer in its housing.
  9. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: passo 17, imagem 1 %32 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: passo 17, imagem 2 %32 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: passo 17, imagem 3 %32
    • Replace the most black thread in the domino.
  10. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: passo 18, imagem 1 %32
    • Replace each room in its housing.
    • Reconnect the carbons.
  11. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: passo 20, imagem 1 %32 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: passo 20, imagem 2 %32
    • Replace the new engine.
    • Remember to recover the small washer at the end of the old piece.
  12. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: passo 21, imagem 1 %32
    • Replace the engine at its location.
  13. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: passo 22, imagem 1 %32 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: passo 22, imagem 2 %32 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: passo 22, imagem 3 %32
    • Be careful to put the black cable back into its housing so as not to block during the reassembly of the machine.
    • Put the carbons back in their place.
  14. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: passo 24, imagem 1 %32 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: passo 24, imagem 2 %32 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: passo 24, imagem 3 %32
    • Replace the shell, then screw it back on.
    • Remember to put the joint back in its place.
  15. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: passo 25, imagem 1 %32 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: passo 25, imagem 2 %32
    • Reposition the part, then lock the engine with a screwdriver to screw.
    • Put the tray back on and screw the screws.
  16. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: passo 26, imagem 1 %32
    • Finally, reposition the vacuum bag.
Linha de Chegada
Um agradecimento especial a esses tradutores:
fr en
100%
HelloMacOS está nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
Céline Chemineau
Membro desde: 01/29/20
16.608 Reputação
Autoria de 95 guias
Equipe
Leroy Merlin Membro de Leroy Merlin
Community
Membros da 37
Autoria de 239 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 161
