Ir para o conteúdo principal
Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable
O que você precisa
  1. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable, Unplug: passo 1, imagem 1 %32
    • Before starting, remember to disconnect the outlet from the mains.
  2. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: passo 2, imagem 1 %32 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: passo 2, imagem 2 %32 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: passo 2, imagem 3 %32
    • Remove the handle, by unscrewing the screw.
  3. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: passo 3, imagem 1 %32 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: passo 3, imagem 2 %32
    • Remove the strip by leverling.
  4. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: passo 4, imagem 1 %32
    • Unscrew the 4 screws.
  5. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: passo 5, imagem 1 %32 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: passo 5, imagem 2 %32
    • Remove the belt, then unscrew the screws from the shell to access the engine.
  6. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: passo 6, imagem 1 %32 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: passo 6, imagem 2 %32
    • Remove the screws from the hull to have access inside and allow the coals to be blocked.
    • Lift the speed variator, you can use a small screwdriver to get it out.
  7. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: passo 8, imagem 1 %32 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: passo 8, imagem 2 %32
    • Turn the dimmer over to have good access to be able to unweld the wires.
    • Unweld the cables connected to the motor and suck the excess with a pump.
  8. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: passo 10, imagem 1 %32 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: passo 10, imagem 2 %32 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: passo 10, imagem 3 %32
    • Unscrew the two screws from the switch to extract the second cable.
    • To extract the cables you can use a clamp.
    • Change the speed variator and then disconnect the cable from the switch.
    • Reseating the motor cables to the dimmer.
  9. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: passo 13, imagem 1 %32 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: passo 13, imagem 2 %32 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: passo 13, imagem 3 %32
    • Replace the dimmer in its housing.
    • Be careful to put the cables back on so that it is not pinched.
  10. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: passo 14, imagem 1 %32
    • Screw the four screws.
  11. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: passo 15, imagem 1 %32 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: passo 15, imagem 2 %32 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: passo 15, imagem 3 %32
    • Replace the tip, strip and handle.
Linha de Chegada
Um agradecimento especial a esses tradutores:
fr en
100%
HelloMacOS está nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
Céline Chemineau
Membro desde: 01/29/20
16.581 Reputação
Autoria de 95 guias
Equipe
Leroy Merlin Membro de Leroy Merlin
Community
Membros da 36
Autoria de 239 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 147
