Ir para o conteúdo principal
Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable
O que você precisa
  1. Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable, Unplug: passo 1, imagem 1 %32
    • Before you start, remember to disconnect the outlet from the mains.
  2. Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: passo 2, imagem 1 %32 Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: passo 2, imagem 2 %32 Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: passo 2, imagem 3 %32
    • Remove the handle, unscrewing the screw.
  3. Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: passo 3, imagem 1 %32 Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: passo 3, imagem 2 %32
    • Pry the tape off.
  4. Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: passo 4, imagem 1 %32 Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: passo 4, imagem 2 %32
    • Unscrew the screws to open the hull.
  5. Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: passo 5, imagem 1 %32
    • Remove the two screws that block the cable.
  6. Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: passo 6, imagem 1 %32 Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: passo 6, imagem 2 %32 Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: passo 6, imagem 3 %32
    • Release the brown cable.
    • Unscrew the screw on the domino.
  7. Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: passo 7, imagem 1 %32 Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: passo 7, imagem 2 %32
    • Then release the blue cable.
  8. Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: passo 8, imagem 1 %32
    • Remove the old cable and replace it with the new one.
  9. Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: passo 9, imagem 1 %32 Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: passo 9, imagem 2 %32 Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: passo 9, imagem 3 %32
    • Put the cables back in their place and screw the domino and switch. Then put each room back into their home.
    • The brown cable must be positioned below.
  10. Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: passo 10, imagem 1 %32
    • Close and screw the device.
  11. Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: passo 11, imagem 1 %32 Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: passo 11, imagem 2 %32
    • Replace the band and handle.
Linha de Chegada
Um agradecimento especial a esses tradutores:
fr en
100%
HelloMacOS está nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
Céline Chemineau
Membro desde: 01/29/20
16.581 Reputação
Autoria de 95 guias
Equipe
Leroy Merlin Membro de Leroy Merlin
Community
Membros da 36
Autoria de 239 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 4
Duração total: 99
