Ir para o conteúdo principal
Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System
O que você precisa
  1. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System, Unplug: passo 1, imagem 1 %32
    • Before starting, remember to disconnect the outlet from the mains.
  2. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: passo 2, imagem 1 %32 Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: passo 2, imagem 2 %32 Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: passo 2, imagem 3 %32
    • Remove the handle, unscrewing the screw
  3. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: passo 3, imagem 1 %32 Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: passo 3, imagem 2 %32
    • Remove the strip by leverling
  4. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: passo 4, imagem 1 %32
    • Remove the front cover to have more space.
  5. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: passo 5, imagem 1 %32
    • Remove the two screws on the shell.
  6. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: passo 6, imagem 1 %32
    • Turn the machine over and unscrew the large screw.
    • Unscrew the orange wheel to be able to lift it.
  7. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: passo 8, imagem 1 %32
    • Remove the spring from the old part to put it back on the new one.
  8. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: passo 9, imagem 1 %32
    • Put the spring back.
    • Tighten the orange wheel.
  9. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: passo 11, imagem 1 %32
    • Put the two screws back on the side and the large screw.
  10. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: passo 12, imagem 1 %32 Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: passo 12, imagem 2 %32 Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: passo 12, imagem 3 %32
    • Replace the tip, strip and handle.
Linha de Chegada
Um agradecimento especial a esses tradutores:
fr en
100%
HelloMacOS está nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
Céline Chemineau
Membro desde: 01/29/20
16.581 Reputação
Autoria de 95 guias
Equipe
Leroy Merlin Membro de Leroy Merlin
Community
Membros da 36
Autoria de 239 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 13
Duração total: 307
