Ir para o conteúdo principal
Dexter Corded Belt Sander - 900BS2.5 Motor Replacement
O que você precisa
  1. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement, Unplug: passo 1, imagem 1 %32
    • Before you begin, remember to disconnect the mains plug.
  2. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: passo 2, imagem 1 %32 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: passo 2, imagem 2 %32 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: passo 2, imagem 3 %32
    • Remove the handle, by unscrewing the screw.
  3. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: passo 3, imagem 1 %32 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: passo 3, imagem 2 %32
    • Pry the tape off.
  4. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: passo 4, imagem 1 %32
    • Unscrew the 4 screws.
  5. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: passo 5, imagem 1 %32 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: passo 5, imagem 2 %32
    • Remove the belt, then unscrew the screws of the shell to gain access to the motor.
    • Collect the belt to place it in the new room.
  6. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: passo 6, imagem 1 %32 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: passo 6, imagem 2 %32 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: passo 6, imagem 3 %32
    • Remove both accessories.
  7. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: passo 7, imagem 1 %32 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: passo 7, imagem 2 %32
    • Remove the screws from the hull in order to have access to the interior and allow the carbon brushes to be blocked.
    • Relax the small metal strip to be able to separate the carbons.
    • Replace the new part in its housing.
  8. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: passo 10, imagem 1 %32 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: passo 10, imagem 2 %32
    • Open the cap of the new part to replace the belt.
    • Tighten the inner screw.
  9. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: passo 11, imagem 1 %32
    • Tighten the four screws.
  10. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: passo 12, imagem 1 %32 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: passo 12, imagem 2 %32 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: passo 12, imagem 3 %32
    • Replace the tip, band and handle.
Linha de Chegada
Um agradecimento especial a esses tradutores:
fr en
100%
HelloMacOS está nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
Céline Chemineau
Membro desde: 01/29/20
16.581 Reputação
Autoria de 95 guias
Equipe
Leroy Merlin Membro de Leroy Merlin
Community
Membros da 36
Autoria de 239 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 10
Duração total: 117
