Ir para o conteúdo principal
Dexter 750W Wired Jigsaw Power Cable Replacement
O que você precisa
  1. Dexter 750W Wired Jigsaw Power Cable Replacement, Unplug: passo 1, imagem 1 %32
    • Before starting, remember to disconnect the outlet from the mains.
  2. Dexter 750W Wired Jigsaw Power Cable Replacement: passo 2, imagem 1 %32
    • Remove the vacuum adaptor on the back of the device.
  3. Dexter 750W Wired Jigsaw Power Cable Replacement: passo 3, imagem 1 %32 Dexter 750W Wired Jigsaw Power Cable Replacement: passo 3, imagem 2 %32
    • Using a screwdriver or screwdriver, unscrew and open the device.
    • Unlock the tray by lifting the lever.
  4. Dexter 750W Wired Jigsaw Power Cable Replacement: passo 4, imagem 1 %32
    • Remove the two screws to unlock the cable.
  5. Dexter 750W Wired Jigsaw Power Cable Replacement: passo 5, imagem 1 %32
    • Remove the black screw, in order to remove the wheel.
    • Thanks to a screwdriver, leverage to be able to recover the wheel.
  6. Dexter 750W Wired Jigsaw Power Cable Replacement: passo 7, imagem 1 %32 Dexter 750W Wired Jigsaw Power Cable Replacement: passo 7, imagem 2 %32
    • Turn the switch over.
    • Unscrew the 2 screws to remove the blue and brown cables.
  7. Dexter 750W Wired Jigsaw Power Cable Replacement: passo 8, imagem 1 %32
    • Reconnect the new cable.
    • The brown thread must be at the top and the blue thread must be at the bottom.
  8. Dexter 750W Wired Jigsaw Power Cable Replacement: passo 9, imagem 1 %32 Dexter 750W Wired Jigsaw Power Cable Replacement: passo 9, imagem 2 %32
    • Reposition each room in its housing.
    • Then screw each screw.
  9. Dexter 750W Wired Jigsaw Power Cable Replacement: passo 10, imagem 1 %32
    • Close and screw the device.
Linha de Chegada
Um agradecimento especial a esses tradutores:
fr en
100%
HelloMacOS está nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
Céline Chemineau
Membro desde: 01/29/20
16.581 Reputação
Autoria de 95 guias
Equipe
Leroy Merlin Membro de Leroy Merlin
Community
Membros da 37
Autoria de 239 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 9
Duração total: 300
