Ir para o conteúdo principal
Dexter 750W Switch Replacement Corded Jigsaw
O que você precisa
  1. Dexter 750W Switch Replacement Corded Jigsaw, Unplug: passo 1, imagem 1 %32
    • Before you begin, remember to disconnect the mains plug.
  2. Dexter 750W Switch Replacement Corded Jigsaw: passo 2, imagem 1 %32
    • Remove the vacuum adapter from the back of the device.
  3. Dexter 750W Switch Replacement Corded Jigsaw: passo 3, imagem 1 %32 Dexter 750W Switch Replacement Corded Jigsaw: passo 3, imagem 2 %32
    • Using a screwdriver or screwdriver, unscrew and open the device.
    • Unlock the tray by lifting the lever.
  4. Dexter 750W Switch Replacement Corded Jigsaw: passo 4, imagem 1 %32
    • Remove the black screw, in order to remove the knob.
    • Using a screwdriver, pry to be able to recover the wheel.
  5. Dexter 750W Switch Replacement Corded Jigsaw: passo 6, imagem 1 %32
    • Turn over the switch, to be able to access the screw.
  6. Dexter 750W Switch Replacement Corded Jigsaw: passo 7, imagem 1 %32
    • Remove the four screws to be able to unlock the system and remove the wires.
  7. Dexter 750W Switch Replacement Corded Jigsaw: passo 8, imagem 1 %32 Dexter 750W Switch Replacement Corded Jigsaw: passo 8, imagem 2 %32
    • Replace the new switch and reseat the wires. Be careful to put each wire back in its place.
    • Following the picture, the red wire is at the top left, the blue wire at the top right, the blue and black wire at the bottom left, and the brown wire at the bottom right.
    • The cables must be placed below so as not to interfere with the closure and must not protrude.
  8. Dexter 750W Switch Replacement Corded Jigsaw: passo 9, imagem 1 %32
    • Put the wheel back in its housing and screw it back on.
  9. Dexter 750W Switch Replacement Corded Jigsaw: passo 10, imagem 1 %32
    • Close and screw the device.
Conclusão
follow guide through or in reverse to reassemble
Um agradecimento especial a esses tradutores:
fr en
100%
HelloMacOS está nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
Céline Chemineau
Membro desde: 01/29/20
16.698 Reputação
Autoria de 95 guias
Equipe
Leroy Merlin Membro de Leroy Merlin
Community
38 Membros
Autoria de 241 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 5
Ao todo: 270
