Ir para o conteúdo principal
Dexter 750W Corded Jigsaw Motor Replacement
O que você precisa
  1. Dexter 750W Corded Jigsaw Motor Replacement, Unplug: passo 1, imagem 1 %32
    • Before you begin, remember to disconnect the mains plug.
  2. Dexter 750W Corded Jigsaw Motor Replacement: passo 2, imagem 1 %32
    • Remove the vacuum adapter from the back of the device.
  3. Dexter 750W Corded Jigsaw Motor Replacement: passo 3, imagem 1 %32 Dexter 750W Corded Jigsaw Motor Replacement: passo 3, imagem 2 %32
    • Using a screwdriver or screwdriver, unscrew and open the device.
    • Unlock the tray by lifting the lever.
    • Use needle nose pliers and remove the clip located next to the blade holder.
    • Remove the blade holder, keeping the slider at the end of the holder.
  4. Dexter 750W Corded Jigsaw Motor Replacement: passo 6, imagem 1 %32
    • Unscrew the two screws and set them aside.
    • Remove the two carbons located next to the stator.
    • Lift the stator, then lever out the motor.
  5. Dexter 750W Corded Jigsaw Motor Replacement: passo 9, imagem 1 %32
    • Put the new motor back in its place.
  6. Dexter 750W Corded Jigsaw Motor Replacement: passo 10, imagem 1 %32 Dexter 750W Corded Jigsaw Motor Replacement: passo 10, imagem 2 %32
    • Collect the end cap on the old engine.
    • Put it back on the new motor.
    • Put some grease on the tip.
  7. Dexter 750W Corded Jigsaw Motor Replacement: passo 11, imagem 1 %32
    • Replace the two screws to stabilize the motor.
    • Return the blade holder to its location
    • Make sure you put each piece in its place.
    • Replace the staple in the same location. The curved side of the staple should go to the rounded side of the bracket.
    • Lubricate the whole
  8. Dexter 750W Corded Jigsaw Motor Replacement: passo 14, imagem 1 %32 Dexter 750W Corded Jigsaw Motor Replacement: passo 14, imagem 2 %32
    • Put the coals back in their places.
  9. Dexter 750W Corded Jigsaw Motor Replacement: passo 15, imagem 1 %32
    • Before closing, lubricate each gear.
  10. Dexter 750W Corded Jigsaw Motor Replacement: passo 16, imagem 1 %32
    • Close and screw the device.
Conclusão
follow guide through or in reverse to reassemble
Um agradecimento especial a esses tradutores:
fr en
100%
HelloMacOS está nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
Céline Chemineau
Membro desde: 01/29/20
16.698 Reputação
Autoria de 95 guias
Equipe
Leroy Merlin Membro de Leroy Merlin
Community
38 Membros
Autoria de 241 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 14
Ao todo: 638
