Ir para o conteúdo principal
Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable
O que você precisa
  1. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable, Unplug: passo 1, imagem 1 %32
    • Before starting, remember to disconnect the outlet from the mains.
  2. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: passo 2, imagem 1 %32 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: passo 2, imagem 2 %32
    • Remove the dust case and the seal on the back of the device.
  3. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: passo 3, imagem 1 %32 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: passo 3, imagem 2 %32 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: passo 3, imagem 3 %32
    • Unscrew the six screws from the pad.
    • Lock the motor with a screwdriver to be able to unscrew the centre screw, you will not be able to get there without blocking the gear.
  4. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: passo 4, imagem 1 %32 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: passo 4, imagem 2 %32
    • Using a screwdriver or screwdriver, unscrew and open the device.
  5. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: passo 5, imagem 1 %32 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: passo 5, imagem 2 %32
    • Unscrew the two screws from the domino to pull out the brown and blue cables.
  6. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: passo 6, imagem 1 %32 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: passo 6, imagem 2 %32
    • Reconnect the new cable to the domino.
    • Then replace the cable, the sheath must arrive between the two pads and the sleeve must be positioned in its housing.
  7. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: passo 7, imagem 1 %32 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: passo 7, imagem 2 %32 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: passo 7, imagem 3 %32
    • Replace the shell, then screw it back on.
    • Remember to put the joint back in its place.
  8. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: passo 8, imagem 1 %32 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: passo 8, imagem 2 %32
    • Reposition the part, then lock the engine with a screwdriver to screw.
    • Put the tray back on and screw the screws.
  9. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: passo 9, imagem 1 %32
    • Finally, reposition the vacuum bag.
Linha de Chegada
Um agradecimento especial a esses tradutores:
fr en
100%
HelloMacOS está nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
Céline Chemineau
Membro desde: 01/29/20
16.608 Reputação
Autoria de 95 guias
Equipe
Leroy Merlin Membro de Leroy Merlin
Community
Membros da 37
Autoria de 239 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 150
