Ir para o conteúdo principal
Dexcom G6 Receiver Display and Front Bezel Replacement
O que você precisa
  1. Dexcom G6 Receiver Display and Front Bezel Replacement, Display and Front Bezel: passo 1, imagem 1 %32
    • Unscrew the 6 Torx T5 screws from the back of the device
  2. Dexcom G6 Receiver Display and Front Bezel Replacement: passo 2, imagem 1 %32 Dexcom G6 Receiver Display and Front Bezel Replacement: passo 2, imagem 2 %32
    • Use a spudger to lift up the screen assembly ribbon cable flap, then remove the ribbon cable.
    • Screen Information: Model AM0310R-04 Lot # NHT18080052
Conclusão
Andrew S
Membro desde: 07/30/21
15.453 Reputação
Autoria de 8 guias
7Comentários do guia
Where can the replacement parts be found? And a charging port?
Ron Magliacane - Responder
Also looking 2 the display. Have 2 dexcom receivers here and both with broken displays.
Jeroen - Responder
I'm not sure if you can find the displays anywhere. The only number (presumably model number) I could find on the screen was AM0310R-04 and the Lot Number NHT18080052.
Andrew S -
Sharewith us where we can find the displays to buy
Jeroen - Responder
I need assistance on a little project I’m working on requiring the display out of the dexcom receiver
Gregory Bassett - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 23
Ao todo: 1,476
