Ir para o conteúdo principal
Dewalt DW511 Hammer Drill Gearcase Replacement
O que você precisa
  1. Dewalt DW511 Hammer Drill Gearcase Replacement, Back Cover: passo 1, imagem 1 %32 Dewalt DW511 Hammer Drill Gearcase Replacement, Back Cover: passo 1, imagem 2 %32 Dewalt DW511 Hammer Drill Gearcase Replacement, Back Cover: passo 1, imagem 3 %32
    • Remove three 19 mm T20 Torx screws from the back of the drill.
  2. Dewalt DW511 Hammer Drill Gearcase Replacement: passo 2, imagem 1 %32 Dewalt DW511 Hammer Drill Gearcase Replacement: passo 2, imagem 2 %32 Dewalt DW511 Hammer Drill Gearcase Replacement: passo 2, imagem 3 %32
    • Place an opening tool in the groove line of the handle and pop the back loose.
    • Grab the drill with two hands and pull the cover off.
  3. Dewalt DW511 Hammer Drill Gearcase Replacement, Power Cord: passo 3, imagem 1 %32 Dewalt DW511 Hammer Drill Gearcase Replacement, Power Cord: passo 3, imagem 2 %32
    • Firmly grab the body of the trigger.
    • Slowly pull the trigger until the entire body is out and only attached by wires.
  4. Dewalt DW511 Hammer Drill Gearcase Replacement: passo 4, imagem 1 %32 Dewalt DW511 Hammer Drill Gearcase Replacement: passo 4, imagem 2 %32 Dewalt DW511 Hammer Drill Gearcase Replacement: passo 4, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • With sharp point tweezers, push the little metal flap up in the hole holding the wire.
    • Clamp the wire with blunt tweezers, and slowly pull the wire out.
  5. Dewalt DW511 Hammer Drill Gearcase Replacement: passo 5, imagem 1 %32 Dewalt DW511 Hammer Drill Gearcase Replacement: passo 5, imagem 2 %32 Dewalt DW511 Hammer Drill Gearcase Replacement: passo 5, imagem 3 %32
    • With a pair of blunt nose tweezers, grab the white wire.
    • Carefully wiggle the wire loose.
    • Pull the wire slowly until it comes out.
  6. Dewalt DW511 Hammer Drill Gearcase Replacement: passo 6, imagem 1 %32
    • With both wires free, the power cord is free from the trigger body.
  7. Dewalt DW511 Hammer Drill Gearcase Replacement, Brushes: passo 7, imagem 1 %32 Dewalt DW511 Hammer Drill Gearcase Replacement, Brushes: passo 7, imagem 2 %32 Dewalt DW511 Hammer Drill Gearcase Replacement, Brushes: passo 7, imagem 3 %32
    • Use an opening tool to lift up the spring holding down the brush.
    • Remove the brush from its holding.
  8. Dewalt DW511 Hammer Drill Gearcase Replacement: passo 8, imagem 1 %32 Dewalt DW511 Hammer Drill Gearcase Replacement: passo 8, imagem 2 %32
    Comprar
    • With a pair of blunt nose tweezers, grab the red wire.
  9. Dewalt DW511 Hammer Drill Gearcase Replacement, Lever Assembly: passo 9, imagem 1 %32 Dewalt DW511 Hammer Drill Gearcase Replacement, Lever Assembly: passo 9, imagem 2 %32 Dewalt DW511 Hammer Drill Gearcase Replacement, Lever Assembly: passo 9, imagem 3 %32
    • Remove two 45 mm T20 Torx screws.
    • Remove one 30 mm T20 Torx screw.
  10. Dewalt DW511 Hammer Drill Gearcase Replacement: passo 10, imagem 1 %32
    • Pull off the top case and set it aside.
  11. Dewalt DW511 Hammer Drill Gearcase Replacement: passo 11, imagem 1 %32 Dewalt DW511 Hammer Drill Gearcase Replacement: passo 11, imagem 2 %32 Dewalt DW511 Hammer Drill Gearcase Replacement: passo 11, imagem 3 %32
    • Grab the gear case cover and gently pull it out just enough to where it exposes the lever assembly.
    • It is important that the brushes are removed before you do this step or you may damage your brushes.
    • The lever assembly can now be lifted out.
  12. Dewalt DW511 Hammer Drill Gearcase Replacement: passo 12, imagem 1 %32
    • With the old lever assembly removed you can now replace it with a new one.
  13. Dewalt DW511 Hammer Drill Gearcase Replacement, Gearcase: passo 13, imagem 1 %32 Dewalt DW511 Hammer Drill Gearcase Replacement, Gearcase: passo 13, imagem 2 %32 Dewalt DW511 Hammer Drill Gearcase Replacement, Gearcase: passo 13, imagem 3 %32
    • Hold the hammer drill tool firmly by the handle.
    • Gently separate the gear case unit from the hammer drill body.
  14. Dewalt DW511 Hammer Drill Gearcase Replacement: passo 14, imagem 1 %32 Dewalt DW511 Hammer Drill Gearcase Replacement: passo 14, imagem 2 %32 Dewalt DW511 Hammer Drill Gearcase Replacement: passo 14, imagem 3 %32
    • The metallic alloy gear case is attached to the armature and removes as a unit. Separation of the gear case from the armature requires specialized hand tools.
    • The third photo shows a gear behind the chuck that interlocks to the gear case.
    • The plastic housing is prone to damage if excessive force is applied during the removal of the gear.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 391
