Ir para o conteúdo principal
Dewalt DCD778 Forward/Reverse Switch Replacement
O que você precisa
  1. Dewalt DCD778 Forward/Reverse Switch  Replacement, Battery: passo 1, imagem 1 %32
    • Grab the drill in one hand and cup the battery (located at the bottom of the drill) with the other hand.
  2. Dewalt DCD778 Forward/Reverse Switch  Replacement: passo 2, imagem 1 %32
    • Use your other hand to push down on the yellow button on the battery.
  3. Dewalt DCD778 Forward/Reverse Switch  Replacement: passo 3, imagem 1 %32
    • Pull the battery in a horizontal direction away from the drill.
  4. Dewalt DCD778 Forward/Reverse Switch  Replacement, Forward/Reverse Switch: passo 4, imagem 1 %32
    • Remove the eight 16 mm, Torx Security #15 screws.
  5. Dewalt DCD778 Forward/Reverse Switch  Replacement: passo 5, imagem 1 %32
    • Lay the drill on its side and gently lift the top half off it.
  6. Dewalt DCD778 Forward/Reverse Switch  Replacement: passo 6, imagem 1 %32
    • Remove the drill mechanism from the shell.
  7. Dewalt DCD778 Forward/Reverse Switch  Replacement: passo 7, imagem 1 %32
    • Disconnect the forward/reverse switch from the trigger by pulling the mechanism out and leaving the switch in the frame.
    • To replace just pull the switch out and put the new one in the opening.
Conclusão
Brittany
Membro desde: 03/09/19
693 Reputação
Autoria de 5 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 37
Duração total: 1,688
