Introdução
RAM(Random Access Memory) is a very fast type of memory. It stores short term information so that it can be accessed quickly. Replacing or upgrading RAM in a computer can help a computer run more quickly and smoothly.
O que você precisa
Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
Unlock the RAM by pressing down on the tabs from either side of the RAM that are securing the RAM to the socket.
- When replacing the RAM, place the replacement into the RAM slot and lock the tabs in.
52 outras pessoas executaram este guia.
4 comentários
very interesting
how to determine the speed
how can i differentiate between types of rams
This depends on the model of system. Some systems have a lever/latch to pull to release the cover. Many Dell and HP models use latches to open the covers (no tools required to open the system). Some systems need a screwdriver to remove the screws. Some are Phillips screws, others may be Torx.
Dave Ellefson - Responder
This is correct.
DistroHopper39B -
