Ir para o conteúdo principal
Desktop PC RAM Replacement
O que você precisa
  1. Desktop PC RAM Replacement, Left Panel: passo 1, imagem 1 %32
    • Unplug the computer from the power supply before any maintenance or disassembly.
    • Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
    • These screws can usually be removed by hand.
    • Be sure to wear an anti-static bracelet or use an anti-static mat to ensure important components are not damaged by static electricity.
    Pergunte ao FixBot
    Comentar
  2. Desktop PC RAM Replacement: passo 2, imagem 1 %32 Desktop PC RAM Replacement: passo 2, imagem 2 %32
    • Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove.
    • If there is a fan mounted on the side panel, make sure to unplug the cable before fully removing the panel.
    Pergunte ao FixBot
    Comentar
  3. Desktop PC RAM Replacement, RAM: passo 3, imagem 1 %32
    • Unlock the RAM by pressing down on the tabs from either side of the RAM that are securing the RAM to the socket.
    Pergunte ao FixBot
    Comentar
  4. Desktop PC RAM Replacement: passo 4, imagem 1 %32
    • Carefully remove the RAM sticks from the computer casing.
    • Repeat the above step and this step as necessary. Some computers could have many sticks of RAM.
    Pergunte ao FixBot
    Comentar
Conclusão
  • When replacing the RAM, place the replacement into the RAM slot and lock the tabs in.
53 outras pessoas executaram este guia.
David Lennon
Membro desde: 04/14/15
10.198 Reputação
Autoria de 10 guias
Equipe
Cal Poly, Team 4-5, Maness Spring 2015 Membro de Cal Poly, Team 4-5, Maness Spring 2015
CPSU-MANESS-S15S4G5
4 Membros
Autoria de 45 guias
4Comentários do guia
can you remove the heat spreader on a corsair vengence led ram?
scar0134 - Responder Compartilhar
very interesting
maciekErd123 - Responder Compartilhar
how to determine the speed
benzy aceware - Responder Compartilhar
how can i differentiate between types of rams
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 24
Últimos 30 dias: 92
Ao todo: 8,878
