Ir para o conteúdo principal
Descaling a Cuisinart 12-Cup Coffee Maker
O que você precisa
  1. Descaling a Cuisinart 12-Cup Coffee Maker, Descaling a Cuisinart 12-Cup Coffee Maker: passo 1, imagem 1 %32 Descaling a Cuisinart 12-Cup Coffee Maker, Descaling a Cuisinart 12-Cup Coffee Maker: passo 1, imagem 2 %32 Descaling a Cuisinart 12-Cup Coffee Maker, Descaling a Cuisinart 12-Cup Coffee Maker: passo 1, imagem 3 %32
    • Fill the coffee maker's glass carafe with 6 cups of cold tap water and 6 cups of distilled white vinegar. Do not mix.
  2. Descaling a Cuisinart 12-Cup Coffee Maker: passo 2, imagem 1 %32 Descaling a Cuisinart 12-Cup Coffee Maker: passo 2, imagem 2 %32 Descaling a Cuisinart 12-Cup Coffee Maker: passo 2, imagem 3 %32
    • Pour the liquid into the coffee maker's water reservoir.
  3. Descaling a Cuisinart 12-Cup Coffee Maker: passo 3, imagem 1 %32 Descaling a Cuisinart 12-Cup Coffee Maker: passo 3, imagem 2 %32 Descaling a Cuisinart 12-Cup Coffee Maker: passo 3, imagem 3 %32
    • Remove the coffee filter holder from the coffee maker.
  4. Descaling a Cuisinart 12-Cup Coffee Maker: passo 4, imagem 1 %32 Descaling a Cuisinart 12-Cup Coffee Maker: passo 4, imagem 2 %32
    • Pull the charcoal filter container out of the coffee maker and remove the filter pod. Wash and dry the filter container.
  5. Descaling a Cuisinart 12-Cup Coffee Maker: passo 5, imagem 1 %32 Descaling a Cuisinart 12-Cup Coffee Maker: passo 5, imagem 2 %32 Descaling a Cuisinart 12-Cup Coffee Maker: passo 5, imagem 3 %32
    • Place a new filter pod in 1 cup of cold tap water; allow it to soak for 15 minutes.
  6. Descaling a Cuisinart 12-Cup Coffee Maker: passo 6, imagem 1 %32 Descaling a Cuisinart 12-Cup Coffee Maker: passo 6, imagem 2 %32
    • Turn the coffee maker's power switch to brew and allow the brew cycle to run.
    • The coffee maker will beep three times when the brew cycle is complete.
  7. Descaling a Cuisinart 12-Cup Coffee Maker: passo 7, imagem 1 %32 Descaling a Cuisinart 12-Cup Coffee Maker: passo 7, imagem 2 %32 Descaling a Cuisinart 12-Cup Coffee Maker: passo 7, imagem 3 %32
    • Pour the hot liquid down the sink drain while running cold water from the tap, so as not to damage the plumbing.
    • As an alternative, remove the carafe from the heat and allow the liquid to cool before pouring it down the drain.
  8. Descaling a Cuisinart 12-Cup Coffee Maker: passo 8, imagem 1 %32 Descaling a Cuisinart 12-Cup Coffee Maker: passo 8, imagem 2 %32 Descaling a Cuisinart 12-Cup Coffee Maker: passo 8, imagem 3 %32
    • Wash the carafe with soap and water; dry it with a clean dish towel.
  9. Descaling a Cuisinart 12-Cup Coffee Maker: passo 9, imagem 1 %32 Descaling a Cuisinart 12-Cup Coffee Maker: passo 9, imagem 2 %32 Descaling a Cuisinart 12-Cup Coffee Maker: passo 9, imagem 3 %32
    • Fill the carafe with 12 cups of cold tap water.
  10. Descaling a Cuisinart 12-Cup Coffee Maker: passo 10, imagem 1 %32 Descaling a Cuisinart 12-Cup Coffee Maker: passo 10, imagem 2 %32 Descaling a Cuisinart 12-Cup Coffee Maker: passo 10, imagem 3 %32
    • Repeat the process of pouring the water into the reservoir, completing the brew cycle, and pouring the water down the drain. Reserve 1 cup of the water.
    • Allow the water to cool, then taste it and see if any vinegar flavor can be detected.
    • If any vinegar flavor can be detected, repeat the process and taste the water again until no vinegar flavor can be detected.
  11. Descaling a Cuisinart 12-Cup Coffee Maker: passo 11, imagem 1 %32 Descaling a Cuisinart 12-Cup Coffee Maker: passo 11, imagem 2 %32
    • Remove the filter pod; discard the water.
  12. Descaling a Cuisinart 12-Cup Coffee Maker: passo 12, imagem 1 %32 Descaling a Cuisinart 12-Cup Coffee Maker: passo 12, imagem 2 %32 Descaling a Cuisinart 12-Cup Coffee Maker: passo 12, imagem 3 %32
    • Place a new filter pod in the container; place the container in the coffee maker.
  13. Descaling a Cuisinart 12-Cup Coffee Maker: passo 13, imagem 1 %32
    • Place the coffee filter holder in the coffee maker.
  14. Descaling a Cuisinart 12-Cup Coffee Maker: passo 14, imagem 1 %32
    • Prepare the coffee maker for brewing and brew coffee as usual. The coffee should brew without issues.
Conclusão
After this project is completed, coffee should brew without issues and taste less murky than it might have before descaling.
Completing this project four to six times per year will keep the coffee maker in good working order. This could prolong the life of the coffee maker and keep it out of the landfill. In addition, it could save money for the owner. That money could be used to purchase better-quality coffee as a reward for keeping the coffee maker in working order.
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 17
Duração total: 651
