Introdução
Before you begin the RAM replacement process, be sure to ground yourself. Grounding yourself prevents short circuiting the device, and/or shocking yourself. An easy way to do so would be to remove one of your shoes.
O que você precisa
Remove the two M2x3mm screws from the center panel on the back of computer with a Phillips #0 screwdriver head.
Uma outra pessoa concluiu este guia.
