Ir para o conteúdo principal
Dell XPS M1730 Keyboard Replacement
O que você precisa
  1. Dell XPS M1730 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Push the sliding button near the battery compartment.
  2. Dell XPS M1730 Keyboard Replacement: passo 2, imagem 1 %32
    • Slide the button next to the battery and lift up on the lip of the battery edge.
  3. Dell XPS M1730 Keyboard Replacement: passo 3, imagem 1 %32 Dell XPS M1730 Keyboard Replacement: passo 3, imagem 2 %32
    • Lift and remove the battery.
  4. Dell XPS M1730 Keyboard Replacement, Keyboard: passo 4, imagem 1 %32 Dell XPS M1730 Keyboard Replacement, Keyboard: passo 4, imagem 2 %32 Dell XPS M1730 Keyboard Replacement, Keyboard: passo 4, imagem 3 %32
    • Remove the plastic trim at the base of the screen screen. Start from the tab on the right side and work to the left side.
  5. Dell XPS M1730 Keyboard Replacement: passo 5, imagem 1 %32 Dell XPS M1730 Keyboard Replacement: passo 5, imagem 2 %32
    • Remove the four screws from the top of the keyboard bracket.
  6. Dell XPS M1730 Keyboard Replacement: passo 6, imagem 1 %32 Dell XPS M1730 Keyboard Replacement: passo 6, imagem 2 %32 Dell XPS M1730 Keyboard Replacement: passo 6, imagem 3 %32
    • Remove the keyboard by sliding it forward, off of the clips, and then lifting up.
  7. Dell XPS M1730 Keyboard Replacement: passo 7, imagem 1 %32 Dell XPS M1730 Keyboard Replacement: passo 7, imagem 2 %32 Dell XPS M1730 Keyboard Replacement: passo 7, imagem 3 %32
    • Lift the keyboard about 2 inches up from the laptop platform.
    • From this angle the keyboard ribbon connector can be seen and disconnected.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 747
