Introdução
How to replace the memory modules of a Dell XPS M170 MXG051.
O que você precisa
Slide the battery-bay latch release on the bottom of the computer and remove the battery from the bay.
Loosen the two captive screws from the memory module cover, and remove the cover.
Align the notch in the new memory module's edge connector with the tab in the connector slot.
Slide the module firmly into the slot at a 45 - degree angle, and press the the module down (so that it is horizontal. If you do not feel the memory module click into place after you press it down, remove the module and reinstall it.
Uma outra pessoa concluiu este guia.
