Ir para o conteúdo principal
Dell XPS M170 MXG051 Hard Drive Replacement
O que você precisa
  1. Dell XPS M170 MXG051 Hard Drive Replacement, Dell XPS M170 MXG051 Battery Removal: passo 1, imagem 1 %32
    • Turn off your computer. Then, disconnect your computer and all attached devices from their electrical outlets.
    • Close the display and turn the computer upside down on a flat work surface.
    • Slide the battery-bay latch release on the bottom of the computer and remove the battery from the bay.
  2. Dell XPS M170 MXG051 Hard Drive Replacement, Remove Hard Drive: passo 2, imagem 1 %32
    • Turn over the computer and remove the two M3 x 3 - mm screws.
    • Slide the hard drive out of the computer.
Conclusão
To reassemble your device, put a new hard drive in the drive bay and follow these instructions in reverse order.
Johnathan Hammond
Membro desde: 02/28/18
44.953 Reputação
Autoria de 408 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.986 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 8
Duração total: 284
