Ir para o conteúdo principal
Dell XPS M1530 Hard Drive Replacement
O que você precisa
  1. Dell XPS M1530 Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Turn the computer upside down with the battery facing you.
    • Turn the computer off and disconnect the charging cable from the computer.
    • Failure to unplug the charging cable may result in electric shock.
  2. Dell XPS M1530 Hard Drive Replacement: passo 2, imagem 1 %32
    • Push the switch as far to the right as possible to unlock the battery.
  3. Dell XPS M1530 Hard Drive Replacement: passo 3, imagem 1 %32 Dell XPS M1530 Hard Drive Replacement: passo 3, imagem 2 %32
    • Remove the battery using two hands and pull it away from the computer.
  4. Dell XPS M1530 Hard Drive Replacement, Hard Drive: passo 4, imagem 1 %32 Dell XPS M1530 Hard Drive Replacement, Hard Drive: passo 4, imagem 2 %32
    • Remove the four Phillips #1 screws holding the Hard Drive in place.
    • Four 3.5mm Phillips #1 screws
  5. Dell XPS M1530 Hard Drive Replacement: passo 5, imagem 1 %32 Dell XPS M1530 Hard Drive Replacement: passo 5, imagem 2 %32
    • Pull the Hard Drive out gently using the tab. It should provide enough leverage to pull the drive out smoothly.
  6. Dell XPS M1530 Hard Drive Replacement: passo 6, imagem 1 %32 Dell XPS M1530 Hard Drive Replacement: passo 6, imagem 2 %32
    • Remove both 3.5mm Phillips #1 screws on either side of the plastic casing.
    • There is a second screw on the other side of the casing.
    • Then gently separate the drive from its casing.
Conclusão
Uma outra pessoa concluiu este guia.
Tyler Scholz
Membro desde: 01/22/15
479 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 18-4, Maness Winter 2015 Membro de Cal Poly, Team 18-4, Maness Winter 2015
CPSU-MANESS-W15S18G4
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 16
Duração total: 2,044
