Ir para o conteúdo principal
Dell XPS M1330 Keyboard Replacement
O que você precisa
  1. Dell XPS M1330 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Flip the laptop on its back, so that the underside is facing up.
  2. Dell XPS M1330 Keyboard Replacement: passo 2, imagem 1 %32
    • Push and hold the slide button to the left and unlock the mechanism.
  3. Dell XPS M1330 Keyboard Replacement: passo 3, imagem 1 %32 Dell XPS M1330 Keyboard Replacement: passo 3, imagem 2 %32
    • Lift the computer up and slowly pull the battery straight out from the device.
  4. Dell XPS M1330 Keyboard Replacement, Hard Drive: passo 4, imagem 1 %32
  5. Dell XPS M1330 Keyboard Replacement: passo 5, imagem 1 %32
    • Remove the four 3.0mm Phillips #1 screws securing the hard drive casing.
  6. Dell XPS M1330 Keyboard Replacement: passo 6, imagem 1 %32 Dell XPS M1330 Keyboard Replacement: passo 6, imagem 2 %32 Dell XPS M1330 Keyboard Replacement: passo 6, imagem 3 %32
    • Slide the hard drive away from the computer, slowly and carefully.
  7. Dell XPS M1330 Keyboard Replacement, Fan: passo 7, imagem 1 %32 Dell XPS M1330 Keyboard Replacement, Fan: passo 7, imagem 2 %32
    • Remove the four 5.0mm screws with a Phillips #1 screwdriver.
    • Remove the one external 5.0mm screw with a Phillips #1 screwdriver.
    • Remove the fan cover.
  8. Dell XPS M1330 Keyboard Replacement: passo 8, imagem 1 %32
    • Remove the four 0.1mm screws using the Phillips #1 screwdriver.
    • Remove the one thicker 0.1 mm screw using the Phillips #1 screwdriver.
  9. Dell XPS M1330 Keyboard Replacement: passo 9, imagem 1 %32
    • Be sure to carefully remove the wires as they are fragile and can rip easily.
    • Remove the wire bay near the fan.
    • Use the long nosed tweezers to carefully handle the white plastic piece that holds the wires together.
    • Gently pull upward while moving your hand side to side so the plastic holder will detach.
  10. Dell XPS M1330 Keyboard Replacement: passo 10, imagem 1 %32
    • Gently remove the fan and its attachments from the bay.
  11. Dell XPS M1330 Keyboard Replacement, CPU: passo 11, imagem 1 %32
    • Using the flathead screwdriver, turn the one screw counterclockwise to loosen the CPU, but do not remove the screw.
  12. Dell XPS M1330 Keyboard Replacement: passo 12, imagem 1 %32
    • Using the iFixit opening tool, prop up the CPU.
  13. Dell XPS M1330 Keyboard Replacement: passo 13, imagem 1 %32
    • Carefully lift the CPU away from its housing.
  14. Dell XPS M1330 Keyboard Replacement, Keyboard: passo 14, imagem 1 %32
    • Unscrew the 5.0mm Phillips #1 screw from the wireless door cover.
    • Pull straight up on the wireless door.
  15. Dell XPS M1330 Keyboard Replacement: passo 15, imagem 1 %32 Dell XPS M1330 Keyboard Replacement: passo 15, imagem 2 %32
    • Unscrew the 3.0mm Phillips #1 screw from the wireless card.
  16. Dell XPS M1330 Keyboard Replacement: passo 16, imagem 1 %32 Dell XPS M1330 Keyboard Replacement: passo 16, imagem 2 %32 Dell XPS M1330 Keyboard Replacement: passo 16, imagem 3 %32
    • Slide the card to the left and up to remove it.
  17. Dell XPS M1330 Keyboard Replacement: passo 17, imagem 1 %32 Dell XPS M1330 Keyboard Replacement: passo 17, imagem 2 %32 Dell XPS M1330 Keyboard Replacement: passo 17, imagem 3 %32
    • Separate the two clips on both sides of the memory sticks.
    • The memory stick will lift up.
    • Gently pull the memory stick up and out of its holder.
    • Repeat these same steps for the second memory stick below.
  18. Dell XPS M1330 Keyboard Replacement: passo 18, imagem 1 %32
    • Remove the two 2.5mm Phillips #1 screws in the battery housing port.
  19. Dell XPS M1330 Keyboard Replacement: passo 19, imagem 1 %32
    • Flip the laptop back over so the cover is on top.
  20. Dell XPS M1330 Keyboard Replacement: passo 20, imagem 1 %32 Dell XPS M1330 Keyboard Replacement: passo 20, imagem 2 %32
    • Carefully open the screen, so it is facing toward yourself.
    • Flatten out the screen as much as possible.
  21. Dell XPS M1330 Keyboard Replacement: passo 21, imagem 1 %32 Dell XPS M1330 Keyboard Replacement: passo 21, imagem 2 %32
    • Carefully lift the computer, so you can get a good grip by the hinges.
    • Carefully lift and remove the central control media button cover from the base.
    • This piece snaps out of its constraints. Be slow and controlled, so you don't break a snap. There is also a cable attached underneath.
  22. Dell XPS M1330 Keyboard Replacement: passo 22, imagem 1 %32
    • Use the Phillips #1 screwdriver to remove the two 3.0mm screws at the top of the keyboard.
  23. Dell XPS M1330 Keyboard Replacement: passo 23, imagem 1 %32 Dell XPS M1330 Keyboard Replacement: passo 23, imagem 2 %32
    • When removing this piece lift slowly as there is a cord underneath that connects to the keyboard.
    • Carefully lift the keyboard up and toward the front screen.
  24. Dell XPS M1330 Keyboard Replacement: passo 24, imagem 1 %32 Dell XPS M1330 Keyboard Replacement: passo 24, imagem 2 %32
    • Lift the keyboard latch toward yourself.
  25. Dell XPS M1330 Keyboard Replacement: passo 25, imagem 1 %32 Dell XPS M1330 Keyboard Replacement: passo 25, imagem 2 %32
    • Gently pull the keyboard cable away from your body.
    • Detach the keyboard cable.
Conclusão
Kai Kapossy
Membro desde: 03/24/19
676 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team S6-G2, Peak Spring 2019 Membro de UMass Dartmouth, Team S6-G2, Peak Spring 2019
UMASSD-PEAK-S19S6G2
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 16
Duração total: 562
