O que você precisa
Unscrew 8 T5 screws. Use an opening tool to pop open the plastic tabs holding the aluminum and carbon fiber shells together.
Insert finger into plastic loop and pull firmly away from motherboard.
Gently unplug the fan connector.
Remove the two PH1 (red) and single PH00 (blue) screws.
The fan may now be lifted from the chassis. Reverse these steps to install the new fan.
Quase terminado!
Conclusão
