Ir para o conteúdo principal
Dell XPS 18 Support Feet Replacement
O que você precisa
  1. Dell XPS 18 Support Feet Replacement, Back Cover: passo 1, imagem 1 %32
    • Turn the device on its screen.
    • Remove the ten 4mm screws using a T8 Torx screwdriver.
  2. Dell XPS 18 Support Feet Replacement: passo 2, imagem 1 %32
    • Gently flip out support feet located near the bottom of device.
  3. Dell XPS 18 Support Feet Replacement: passo 3, imagem 1 %32
    • Gently lift the back cover off the device. The back cover should come off easily.
  4. Dell XPS 18 Support Feet Replacement, Support Feet: passo 4, imagem 1 %32
    • Fold down the support foot.
  5. Dell XPS 18 Support Feet Replacement: passo 5, imagem 1 %32
    • Remove the two silver 3mm screws with a Phillips 00 screwdriver.
  6. Dell XPS 18 Support Feet Replacement: passo 6, imagem 1 %32
    • Remove the silver metal piece holding the support feet down.
  7. Dell XPS 18 Support Feet Replacement: passo 7, imagem 1 %32
    • Remove the support foot.
    • Follow these same steps for the remaining support foot.
Conclusão
Austin Weir
Membro desde: 01/31/15
1.287 Reputação
Autoria de 8 guias
Equipe
Cal Poly, Team 6-29, Amido Winter 2015 Membro de Cal Poly, Team 6-29, Amido Winter 2015
CPSU-AMIDO-W15S6G29
Membros da 4
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 15
Duração total: 2,007
