Ir para o conteúdo principal
Dell XPS 18 Left and Right Speakers Replacement
O que você precisa
  1. Dell XPS 18 Left and Right Speakers Replacement, Back Cover: passo 1, imagem 1 %32
    • Turn the device on its screen.
    • Remove the ten 4mm screws using a T8 Torx screwdriver.
  2. Dell XPS 18 Left and Right Speakers Replacement: passo 2, imagem 1 %32
    • Gently flip out support feet located near the bottom of device.
  3. Dell XPS 18 Left and Right Speakers Replacement: passo 3, imagem 1 %32
    • Gently lift the back cover off the device. The back cover should come off easily.
  4. Dell XPS 18 Left and Right Speakers Replacement, Left and Right Speakers: passo 4, imagem 1 %32 Dell XPS 18 Left and Right Speakers Replacement, Left and Right Speakers: passo 4, imagem 2 %32
    • Use the plastic opening tool's angled edge to lift the clasp securing the copper colored volume control cable.
    • Disconnect the volume control cable and pull it back.
  5. Dell XPS 18 Left and Right Speakers Replacement: passo 5, imagem 1 %32
    • Firmly pull the blue speaker cable loose.
  6. Dell XPS 18 Left and Right Speakers Replacement: passo 6, imagem 1 %32
    • Remove the two black 4mm screws with a Phillips 00 screwdriver.
  7. Dell XPS 18 Left and Right Speakers Replacement: passo 7, imagem 1 %32
    • Carefully remove the speaker.
    • To remove the right speaker, follow these same steps.
Conclusão
Uma outra pessoa concluiu este guia.
Austin Weir
Membro desde: 01/31/15
1.287 Reputação
Autoria de 8 guias
Equipe
Cal Poly, Team 6-29, Amido Winter 2015 Membro de Cal Poly, Team 6-29, Amido Winter 2015
CPSU-AMIDO-W15S6G29
Membros da 4
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Duração total: 1,296
