Ir para o conteúdo principal
Dell XPS 18 Battery Replacement
O que você precisa
  1. Dell XPS 18 Battery Replacement, Back Cover: passo 1, imagem 1 %32
    • Turn the device on its screen.
    • Remove the ten 4mm screws using a T8 Torx screwdriver.
  2. Dell XPS 18 Battery Replacement: passo 2, imagem 1 %32
    • Gently flip out support feet located near the bottom of device.
  3. Dell XPS 18 Battery Replacement: passo 3, imagem 1 %32
    • Gently lift the back cover off the device. The back cover should come off easily.
  4. Dell XPS 18 Battery Replacement, Internal Cover: passo 4, imagem 1 %32
    • Use the opening tool's angled edge to lift the clasps securing the screen and motherboard cables.
  5. Dell XPS 18 Battery Replacement: passo 5, imagem 1 %32 Dell XPS 18 Battery Replacement: passo 5, imagem 2 %32
    • Disconnect the screen and copper colored motherboard cables and tuck them under the device to prevent future hassle.
  6. Dell XPS 18 Battery Replacement: passo 6, imagem 1 %32 Dell XPS 18 Battery Replacement: passo 6, imagem 2 %32
    • Remove the two black 3mm screws from the internal cover with a Phillips 00 screwdriver.
    • Remove the internal cover.
  7. Dell XPS 18 Battery Replacement, Touch Control Board: passo 7, imagem 1 %32 Dell XPS 18 Battery Replacement, Touch Control Board: passo 7, imagem 2 %32
    • Disconnect the black camera cable and pull it back to prevent future hassle.
  8. Dell XPS 18 Battery Replacement: passo 8, imagem 1 %32 Dell XPS 18 Battery Replacement: passo 8, imagem 2 %32
    • Use the angled edge of the plastic opening tool to lift the clasp securing the touch control board cable.
    • Disconnect the silver and blue touch control board cable.
  9. Dell XPS 18 Battery Replacement: passo 9, imagem 1 %32 Dell XPS 18 Battery Replacement: passo 9, imagem 2 %32
    • Remove the two silver 3mm screws holding the touch control board in place with a Phillips 00 screwdriver.
    • Remove the touch control board.
  10. Dell XPS 18 Battery Replacement, Wireless WLAN Card Wires: passo 10, imagem 1 %32
    • Use the plastic opening tool's angled edge to remove the black and white wires connected to the wireless WLAN card.
  11. Dell XPS 18 Battery Replacement: passo 11, imagem 1 %32 Dell XPS 18 Battery Replacement: passo 11, imagem 2 %32
    • Pull back the cables.
  12. Dell XPS 18 Battery Replacement, Battery: passo 12, imagem 1 %32
    • Use the plastic opening tool's angled edge to pry the black battery cable loose.
  13. Dell XPS 18 Battery Replacement: passo 13, imagem 1 %32
    • Use the plastic opening tool's angled edge to remove the red and black CMOS battery cable.
  14. Dell XPS 18 Battery Replacement: passo 14, imagem 1 %32 Dell XPS 18 Battery Replacement: passo 14, imagem 2 %32
    • Use the plastic opening tool's angled edge to lift the clasp securing the silver circuit board cable.
    • Pull back the circuit board cable to prevent future hassle.
  15. Dell XPS 18 Battery Replacement: passo 15, imagem 1 %32
    • Use the opening tool's angled edge to remove the CMOS battery.
    • The CMOS battery is adhered with strong adhesive; you may need to use extra force when removing.
  16. Dell XPS 18 Battery Replacement: passo 16, imagem 1 %32
    • Remove the eleven black 4mm screws holding the battery in place with a Phillips 00 screwdriver.
  17. Dell XPS 18 Battery Replacement: passo 17, imagem 1 %32
    • Remove the battery.
Conclusão
13 outras pessoas executaram este guia.
Austin Weir
Membro desde: 01/31/15
1.287 Reputação
Autoria de 8 guias
Equipe
Cal Poly, Team 6-29, Amido Winter 2015 Membro de Cal Poly, Team 6-29, Amido Winter 2015
CPSU-AMIDO-W15S6G29
Membros da 4
Autoria de 16 guias
9 comentários
needs the help to repair the Dell XPS18
anrew waleta - Responder
This is an excellent doc! Pictures are really clear and accurate, steps are concise and best of all they are correct. I was able to solve my issue the first go round with these instructions. Kudos to the author and thanks a million for the assistance!
stacysaw - Responder
It all worked good. Thanks.
Kenneth Macdonald - Responder
Excellent!
What is the battery type and where to buy, thanks
Mohammad - Responder
My unit is missing the right foot stand. Is there anywhere else I can find the model number. Need to purchase a new power supply?
Also might need to replace the touchscreen its cracked. Have to power her up first to find out. Do you have a video for touchscreen replacement?
Frank Schofield - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 57
Duração total: 15,951
