Ir para o conteúdo principal
Dell XPS 17 L702X Palm Rest Replacement
O que você precisa
  1. Dell XPS 17 L702X Palm Rest Replacement, Battery: passo 1, imagem 1 %32
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Flip over the laptop so that the bottom battery compartment faces upwards.
  2. Dell XPS 17 L702X Palm Rest Replacement: passo 2, imagem 1 %32 Dell XPS 17 L702X Palm Rest Replacement: passo 2, imagem 2 %32
    • Slide the tab below the battery to the left and hold the tab in place.
  3. Dell XPS 17 L702X Palm Rest Replacement: passo 3, imagem 1 %32 Dell XPS 17 L702X Palm Rest Replacement: passo 3, imagem 2 %32
    • While holding the tab, lift the battery out of its compartment.
    • Release the tab after removing the battery.
  4. Dell XPS 17 L702X Palm Rest Replacement, Hard Drive: passo 4, imagem 1 %32
    • Loosen the module cover screw with a Phillips screwdriver.
    • The screw is attached to the cover; do not force it out.
  5. Dell XPS 17 L702X Palm Rest Replacement: passo 5, imagem 1 %32 Dell XPS 17 L702X Palm Rest Replacement: passo 5, imagem 2 %32 Dell XPS 17 L702X Palm Rest Replacement: passo 5, imagem 3 %32
    • Lift the module cover by inserting a plastic opening tool into the crevice near the screw and lift upwards.
  6. Dell XPS 17 L702X Palm Rest Replacement: passo 6, imagem 1 %32 Dell XPS 17 L702X Palm Rest Replacement: passo 6, imagem 2 %32
    • Remove the four 4mm Phillips screws fastening the first hard drive.
  7. Dell XPS 17 L702X Palm Rest Replacement: passo 7, imagem 1 %32 Dell XPS 17 L702X Palm Rest Replacement: passo 7, imagem 2 %32 Dell XPS 17 L702X Palm Rest Replacement: passo 7, imagem 3 %32
    • Slide the hard drive with your hand towards the hole where the back panel assembly screw was located (in step 5) to disconnect it.
    • Lift the hard drive up to remove it from the case.
  8. Dell XPS 17 L702X Palm Rest Replacement: passo 8, imagem 1 %32
    • Remove the four 4mm Phillips screws on the second hard drive.
  9. Dell XPS 17 L702X Palm Rest Replacement: passo 9, imagem 1 %32 Dell XPS 17 L702X Palm Rest Replacement: passo 9, imagem 2 %32
    • Slide the hard drive towards the edge nearest you to disconnect it.
  10. Dell XPS 17 L702X Palm Rest Replacement: passo 10, imagem 1 %32 Dell XPS 17 L702X Palm Rest Replacement: passo 10, imagem 2 %32 Dell XPS 17 L702X Palm Rest Replacement: passo 10, imagem 3 %32
    • Using the tab that says "THIS SIDE UP," pull away from the laptop to remove the hard drive.
  11. Dell XPS 17 L702X Palm Rest Replacement: passo 11, imagem 1 %32 Dell XPS 17 L702X Palm Rest Replacement: passo 11, imagem 2 %32
    • Repeat this step for each hard drive.
    • Unscrew the two 4mm screws from each side of the hard drive casing with a Phillips screwdriver.
  12. Dell XPS 17 L702X Palm Rest Replacement: passo 12, imagem 1 %32
    • Remove the hard drive casing.
  13. Dell XPS 17 L702X Palm Rest Replacement, Palm Rest: passo 13, imagem 1 %32
    • Unscrew the screw holding the optical drive with a Phillips screwdriver.
  14. Dell XPS 17 L702X Palm Rest Replacement: passo 14, imagem 1 %32 Dell XPS 17 L702X Palm Rest Replacement: passo 14, imagem 2 %32 Dell XPS 17 L702X Palm Rest Replacement: passo 14, imagem 3 %32
    • Using a plastic opening tool, pull out the optical drive.
  15. Dell XPS 17 L702X Palm Rest Replacement: passo 15, imagem 1 %32
    • Unscrew three 4mm screws near the edge of the optical drive compartment with a Phillips screwdriver.
  16. Dell XPS 17 L702X Palm Rest Replacement: passo 16, imagem 1 %32
    • Open the laptop to about a 90 degree angle and place it on its side with the empty optical drive slot pointing upwards.
  17. Dell XPS 17 L702X Palm Rest Replacement: passo 17, imagem 1 %32 Dell XPS 17 L702X Palm Rest Replacement: passo 17, imagem 2 %32 Dell XPS 17 L702X Palm Rest Replacement: passo 17, imagem 3 %32
    • Push and hold the tab inside the optical drive's opening with your index finger.
    • Insert a spudger between the black and silver plastic pieces that are above the tab and pry apart the two pieces.
  18. Dell XPS 17 L702X Palm Rest Replacement: passo 18, imagem 1 %32 Dell XPS 17 L702X Palm Rest Replacement: passo 18, imagem 2 %32
    • Slide the spudger around the palm rest to release the clips.
    • You may hear a crackling noise; this is normal.
    • Use caution when sliding below the mouse pad, as there are wires we must detach in the next steps.
  19. Dell XPS 17 L702X Palm Rest Replacement: passo 19, imagem 1 %32 Dell XPS 17 L702X Palm Rest Replacement: passo 19, imagem 2 %32
    • Gently lift and rotate the palm rest panel until it's upside down as it is still connected by the mouse pad wires.
    • The mouse pad wires are still connected to the palm rest panel.
  20. Dell XPS 17 L702X Palm Rest Replacement: passo 20, imagem 1 %32 Dell XPS 17 L702X Palm Rest Replacement: passo 20, imagem 2 %32 Dell XPS 17 L702X Palm Rest Replacement: passo 20, imagem 3 %32
    • Put the spudger below the black tab of the wider cable and push up to release.
    • Gently pull out the cable.
  21. Dell XPS 17 L702X Palm Rest Replacement: passo 21, imagem 1 %32 Dell XPS 17 L702X Palm Rest Replacement: passo 21, imagem 2 %32 Dell XPS 17 L702X Palm Rest Replacement: passo 21, imagem 3 %32
    • Insert the spudger below the black tab of the remaining cable and push up to release.
  22. Dell XPS 17 L702X Palm Rest Replacement: passo 22, imagem 1 %32
    • Remove the palm rest from the laptop.
Conclusão
Uma outra pessoa concluiu este guia.
Shin Sul
Membro desde: 10/02/15
544 Reputação
Autoria de 3 guias
Equipe
CSU Fullerton, Team 2-6, Bruce Fall 2015 Membro de CSU Fullerton, Team 2-6, Bruce Fall 2015
CSUF-BRUCE-F15S2G6
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Duração total: 1,158
