Introdução
If the motherboard of your Dell XPS 17 L702X laptop is broken, or you are upgrading your PC’s hardware and the current motherboard doesn’t have the input/output necessary to support the new hardware, use this guide the remove and replace the motherboard.
The motherboard of a computer is a firm sheet of non-conductive material with thin layers of conductive metal printed onto the board, known as traces. These traces form circuits necessary for the electrical connections between the various components of the computer.
Before beginning, make sure to completely power off your laptop and disconnect it from any external power source.
O que você precisa
Using the plastic opening tool, slightly lift and rotate the keyboard until it's upside down from the display side of the laptop.
Close the display, and flip the laptop over so that the bottom faces upwards.
Remove the two 16 mm screws with a Phillips screwdriver.
Insert the pointy side of the spudger below the golden connector of the white cable on the WLAN card and lift to detach.
Unscrew the ten 8mm screws from the grey inner casing with a Phillips screwdriver.
Gently flip the laptop with its bottom facing you.
Remove the four 8mm screws with a Phillips screwdriver.
Remove the two 16mm battery casing screws with a Phillips screwdriver.
Remove the two 16mm corner screws with a Phillips screwdriver.
Remove the two 4mm screws inside battery housing with a Phillips screwdriver.
Holding the opening from the optical drive in one hand with the other hand holding the opposite side of the laptop, lift and remove the back cover assembly.
Make sure you remember to remove the SD card cover before pulling off the back cover
10 outras pessoas executaram este guia.
4 comentários
it really helped me out with my extremely fast overheating pc. and now it is mutch cooler and working great, Thanks!
Great step by step guide with excellent photos helped me to reapply Thermal paste to my CPU/GPU heatsink.
Thank you!
