Ir para o conteúdo principal
Dell XPS 17 L702X Hard Drive Replacement
O que você precisa
  1. Dell XPS 17 L702X Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Flip over the laptop so that the bottom battery compartment faces upwards.
  2. Dell XPS 17 L702X Hard Drive Replacement: passo 2, imagem 1 %32 Dell XPS 17 L702X Hard Drive Replacement: passo 2, imagem 2 %32
    • Slide the tab below the battery to the left and hold the tab in place.
  3. Dell XPS 17 L702X Hard Drive Replacement: passo 3, imagem 1 %32 Dell XPS 17 L702X Hard Drive Replacement: passo 3, imagem 2 %32
    • While holding the tab, lift the battery out of its compartment.
    • Release the tab after removing the battery.
  4. Dell XPS 17 L702X Hard Drive Replacement, Hard Drive: passo 4, imagem 1 %32
    • Loosen the module cover screw with a Phillips screwdriver.
    • The screw is attached to the cover; do not force it out.
  5. Dell XPS 17 L702X Hard Drive Replacement: passo 5, imagem 1 %32 Dell XPS 17 L702X Hard Drive Replacement: passo 5, imagem 2 %32 Dell XPS 17 L702X Hard Drive Replacement: passo 5, imagem 3 %32
    • Lift the module cover by inserting a plastic opening tool into the crevice near the screw and lift upwards.
  6. Dell XPS 17 L702X Hard Drive Replacement: passo 6, imagem 1 %32 Dell XPS 17 L702X Hard Drive Replacement: passo 6, imagem 2 %32
    • Remove the four 4mm Phillips screws fastening the first hard drive.
  7. Dell XPS 17 L702X Hard Drive Replacement: passo 7, imagem 1 %32 Dell XPS 17 L702X Hard Drive Replacement: passo 7, imagem 2 %32 Dell XPS 17 L702X Hard Drive Replacement: passo 7, imagem 3 %32
    • Slide the hard drive with your hand towards the hole where the back panel assembly screw was located (in step 5) to disconnect it.
    • Lift the hard drive up to remove it from the case.
  8. Dell XPS 17 L702X Hard Drive Replacement: passo 8, imagem 1 %32
    • Remove the four 4mm Phillips screws on the second hard drive.
  9. Dell XPS 17 L702X Hard Drive Replacement: passo 9, imagem 1 %32 Dell XPS 17 L702X Hard Drive Replacement: passo 9, imagem 2 %32
    • Slide the hard drive towards the edge nearest you to disconnect it.
  10. Dell XPS 17 L702X Hard Drive Replacement: passo 10, imagem 1 %32 Dell XPS 17 L702X Hard Drive Replacement: passo 10, imagem 2 %32 Dell XPS 17 L702X Hard Drive Replacement: passo 10, imagem 3 %32
    • Using the tab that says "THIS SIDE UP," pull away from the laptop to remove the hard drive.
  11. Dell XPS 17 L702X Hard Drive Replacement: passo 11, imagem 1 %32 Dell XPS 17 L702X Hard Drive Replacement: passo 11, imagem 2 %32
    • Repeat this step for each hard drive.
    • Unscrew the two 4mm screws from each side of the hard drive casing with a Phillips screwdriver.
  12. Dell XPS 17 L702X Hard Drive Replacement: passo 12, imagem 1 %32
    • Remove the hard drive casing.
Conclusão
6 outras pessoas executaram este guia.
Shin Sul
Membro desde: 10/02/15
544 Reputação
Autoria de 3 guias
Equipe
CSU Fullerton, Team 2-6, Bruce Fall 2015 Membro de CSU Fullerton, Team 2-6, Bruce Fall 2015
CSUF-BRUCE-F15S2G6
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 20
Duração total: 4,341
