Ir para o conteúdo principal
Dell XPS 17 L702X Display Replacement
O que você precisa
  1. Dell XPS 17 L702X Display Replacement, Battery: passo 1, imagem 1 %32
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Flip over the laptop so that the bottom battery compartment faces upwards.
  2. Dell XPS 17 L702X Display Replacement: passo 2, imagem 1 %32 Dell XPS 17 L702X Display Replacement: passo 2, imagem 2 %32
    • Slide the tab below the battery to the left and hold the tab in place.
  3. Dell XPS 17 L702X Display Replacement: passo 3, imagem 1 %32 Dell XPS 17 L702X Display Replacement: passo 3, imagem 2 %32
    • While holding the tab, lift the battery out of its compartment.
    • Release the tab after removing the battery.
  4. Dell XPS 17 L702X Display Replacement, Hard Drive: passo 4, imagem 1 %32
    • Loosen the module cover screw with a Phillips screwdriver.
    • The screw is attached to the cover; do not force it out.
  5. Dell XPS 17 L702X Display Replacement: passo 5, imagem 1 %32 Dell XPS 17 L702X Display Replacement: passo 5, imagem 2 %32 Dell XPS 17 L702X Display Replacement: passo 5, imagem 3 %32
    • Lift the module cover by inserting a plastic opening tool into the crevice near the screw and lift upwards.
  6. Dell XPS 17 L702X Display Replacement: passo 6, imagem 1 %32 Dell XPS 17 L702X Display Replacement: passo 6, imagem 2 %32
    • Remove the four 4mm Phillips screws fastening the first hard drive.
  7. Dell XPS 17 L702X Display Replacement: passo 7, imagem 1 %32 Dell XPS 17 L702X Display Replacement: passo 7, imagem 2 %32 Dell XPS 17 L702X Display Replacement: passo 7, imagem 3 %32
    • Slide the hard drive with your hand towards the hole where the back panel assembly screw was located (in step 5) to disconnect it.
    • Lift the hard drive up to remove it from the case.
  8. Dell XPS 17 L702X Display Replacement: passo 8, imagem 1 %32
    • Remove the four 4mm Phillips screws on the second hard drive.
  9. Dell XPS 17 L702X Display Replacement: passo 9, imagem 1 %32 Dell XPS 17 L702X Display Replacement: passo 9, imagem 2 %32
    • Slide the hard drive towards the edge nearest you to disconnect it.
  10. Dell XPS 17 L702X Display Replacement: passo 10, imagem 1 %32 Dell XPS 17 L702X Display Replacement: passo 10, imagem 2 %32 Dell XPS 17 L702X Display Replacement: passo 10, imagem 3 %32
    • Using the tab that says "THIS SIDE UP," pull away from the laptop to remove the hard drive.
  11. Dell XPS 17 L702X Display Replacement: passo 11, imagem 1 %32 Dell XPS 17 L702X Display Replacement: passo 11, imagem 2 %32
    • Repeat this step for each hard drive.
    • Unscrew the two 4mm screws from each side of the hard drive casing with a Phillips screwdriver.
  12. Dell XPS 17 L702X Display Replacement: passo 12, imagem 1 %32
    • Remove the hard drive casing.
  13. Dell XPS 17 L702X Display Replacement, Palm Rest: passo 13, imagem 1 %32
    • Unscrew the screw holding the optical drive with a Phillips screwdriver.
  14. Dell XPS 17 L702X Display Replacement: passo 14, imagem 1 %32 Dell XPS 17 L702X Display Replacement: passo 14, imagem 2 %32 Dell XPS 17 L702X Display Replacement: passo 14, imagem 3 %32
    • Using a plastic opening tool, pull out the optical drive.
  15. Dell XPS 17 L702X Display Replacement: passo 15, imagem 1 %32
    • Unscrew three 4mm screws near the edge of the optical drive compartment with a Phillips screwdriver.
  16. Dell XPS 17 L702X Display Replacement: passo 16, imagem 1 %32
    • Open the laptop to about a 90 degree angle and place it on its side with the empty optical drive slot pointing upwards.
  17. Dell XPS 17 L702X Display Replacement: passo 17, imagem 1 %32 Dell XPS 17 L702X Display Replacement: passo 17, imagem 2 %32 Dell XPS 17 L702X Display Replacement: passo 17, imagem 3 %32
    • Push and hold the tab inside the optical drive's opening with your index finger.
    • Insert a spudger between the black and silver plastic pieces that are above the tab and pry apart the two pieces.
  18. Dell XPS 17 L702X Display Replacement: passo 18, imagem 1 %32 Dell XPS 17 L702X Display Replacement: passo 18, imagem 2 %32
    • Slide the spudger around the palm rest to release the clips.
    • You may hear a crackling noise; this is normal.
    • Use caution when sliding below the mouse pad, as there are wires we must detach in the next steps.
  19. Dell XPS 17 L702X Display Replacement: passo 19, imagem 1 %32 Dell XPS 17 L702X Display Replacement: passo 19, imagem 2 %32
    • Gently lift and rotate the palm rest panel until it's upside down as it is still connected by the mouse pad wires.
    • The mouse pad wires are still connected to the palm rest panel.
  20. Dell XPS 17 L702X Display Replacement: passo 20, imagem 1 %32 Dell XPS 17 L702X Display Replacement: passo 20, imagem 2 %32 Dell XPS 17 L702X Display Replacement: passo 20, imagem 3 %32
    • Put the spudger below the black tab of the wider cable and push up to release.
    • Gently pull out the cable.
  21. Dell XPS 17 L702X Display Replacement: passo 21, imagem 1 %32 Dell XPS 17 L702X Display Replacement: passo 21, imagem 2 %32 Dell XPS 17 L702X Display Replacement: passo 21, imagem 3 %32
    • Insert the spudger below the black tab of the remaining cable and push up to release.
  22. Dell XPS 17 L702X Display Replacement: passo 22, imagem 1 %32
    • Remove the palm rest from the laptop.
  23. Dell XPS 17 L702X Display Replacement, Keyboard: passo 23, imagem 1 %32 Dell XPS 17 L702X Display Replacement, Keyboard: passo 23, imagem 2 %32 Dell XPS 17 L702X Display Replacement, Keyboard: passo 23, imagem 3 %32
    • Using the plastic opening tool, slightly lift and rotate the keyboard until it's upside down from the display side of the laptop.
    • DO NOT lift the keyboard all the way up as there are wires that are still connected.
  24. Dell XPS 17 L702X Display Replacement: passo 24, imagem 1 %32 Dell XPS 17 L702X Display Replacement: passo 24, imagem 2 %32 Dell XPS 17 L702X Display Replacement: passo 24, imagem 3 %32
    • Gently insert the spudger below the edge of the black tab of the thin, copper colored cable and pry it open.
  25. Dell XPS 17 L702X Display Replacement: passo 25, imagem 1 %32 Dell XPS 17 L702X Display Replacement: passo 25, imagem 2 %32 Dell XPS 17 L702X Display Replacement: passo 25, imagem 3 %32
    • Gently insert the spudger under the edge of the black tab of the cable marked "UP" and pry it open.
  26. Dell XPS 17 L702X Display Replacement: passo 26, imagem 1 %32
    • Remove the keyboard from the laptop.
  27. Dell XPS 17 L702X Display Replacement, Display: passo 27, imagem 1 %32 Dell XPS 17 L702X Display Replacement, Display: passo 27, imagem 2 %32
    • Close the display, and flip the laptop over so that the bottom faces upwards.
    • Remove the two 16 mm screws with a Phillips screwdriver.
  28. Dell XPS 17 L702X Display Replacement: passo 28, imagem 1 %32
    • Gently flip over the laptop and open the back cover assembly.
  29. Dell XPS 17 L702X Display Replacement: passo 29, imagem 1 %32 Dell XPS 17 L702X Display Replacement: passo 29, imagem 2 %32 Dell XPS 17 L702X Display Replacement: passo 29, imagem 3 %32
    • Insert the pointy side of the spudger below the golden connector of the white cable on the WLAN card and lift to detach.
  30. Dell XPS 17 L702X Display Replacement: passo 30, imagem 1 %32 Dell XPS 17 L702X Display Replacement: passo 30, imagem 2 %32 Dell XPS 17 L702X Display Replacement: passo 30, imagem 3 %32
    • Unscrew the 4mm screw from the WLAN card with a Phillips screwdriver. The card will lift itself after you remove the 4mm screw.
    • Gently pull out the WLAN card.
  31. Dell XPS 17 L702X Display Replacement: passo 31, imagem 1 %32 Dell XPS 17 L702X Display Replacement: passo 31, imagem 2 %32 Dell XPS 17 L702X Display Replacement: passo 31, imagem 3 %32
    • Insert the pointy side of the spudger below the golden color connector of the gray cable on the WWAN card and lift to detach.
    • Insert the pointy side of the spudger below the golden color connector of the black cable on the WWAN card and lift to detach.
  32. Dell XPS 17 L702X Display Replacement: passo 32, imagem 1 %32 Dell XPS 17 L702X Display Replacement: passo 32, imagem 2 %32 Dell XPS 17 L702X Display Replacement: passo 32, imagem 3 %32
    • Unscrew the 4mm screw from the WWAN card with a Phillips screwdriver. The card will lift itself.
    • Gently pull out the WWAN card.
  33. Dell XPS 17 L702X Display Replacement: passo 33, imagem 1 %32 Dell XPS 17 L702X Display Replacement: passo 33, imagem 2 %32 Dell XPS 17 L702X Display Replacement: passo 33, imagem 3 %32
    • Gently remove the wires for the WLAN and WWAN cards from their housing.
  34. Dell XPS 17 L702X Display Replacement: passo 34, imagem 1 %32
    • Unscrew four the 8mm screws directly under the keyboard with a Phillips screwdriver.
  35. Dell XPS 17 L702X Display Replacement: passo 35, imagem 1 %32 Dell XPS 17 L702X Display Replacement: passo 35, imagem 2 %32
    • Loosen the grounding screw attached to the black monitor cable with a Phillips screwdriver.
    • DO NOT ATTEMPT TO REMOVE THE SCREW FROM THE WIRE. The screw is permanently fixed onto the wire.
  36. Dell XPS 17 L702X Display Replacement: passo 36, imagem 1 %32 Dell XPS 17 L702X Display Replacement: passo 36, imagem 2 %32
    • Using the plastic opening tool, detach the connection from the cable to the board.
  37. Dell XPS 17 L702X Display Replacement: passo 37, imagem 1 %32
    • Gently remove the monitor cable from its holdings from the board.
  38. Dell XPS 17 L702X Display Replacement: passo 38, imagem 1 %32 Dell XPS 17 L702X Display Replacement: passo 38, imagem 2 %32 Dell XPS 17 L702X Display Replacement: passo 38, imagem 3 %32
    • Hold the plastic edge of the display firmly and lift to remove the display.
Conclusão
4 outras pessoas executaram este guia.
Monica Oropeza
Membro desde: 09/17/15
381 Reputação
Autoria de 2 guias
Equipe
CSU Fullerton, Team 2-6, Bruce Fall 2015 Membro de CSU Fullerton, Team 2-6, Bruce Fall 2015
CSUF-BRUCE-F15S2G6
Membros da 4
Autoria de 8 guias
4 comentários
I have a question, my dell xps 17 l702x is having display issues. I've had it for about 6 years now and was using the original battery for that whole time, ( I know that's a long battery life), but my battery died and replaced it (battery plus bulbs) and now the display goes in and out and looks like it crashes then within 20 seconds, it comes back. Wondering what's going on. Any help is appreciated
Justin - Responder
Does it “flicker”/”spazz out” really weirdly when only on battery power? Try going into the Intel control panel and disabling the “Intel Power Saving Technology”
watercannons -
dell xps 17 l702x sir could you please tell me the best place to buy replacement screen?
Aashish George - Responder
dell xps 17 l702x please tell me the screen product number, would you guys fix it if I send it over? Do you guys have any branches in Delhi India?
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 14
Duração total: 4,817
