Ir para o conteúdo principal
Dell XPS 15 Memory Replacement
O que você precisa
  1. Dell XPS 15 Memory Replacement, Memory: passo 1, imagem 1 %32
    • First turn notebook upside down.
  2. Dell XPS 15 Memory Replacement: passo 2, imagem 1 %32 Dell XPS 15 Memory Replacement: passo 2, imagem 2 %32
    • Take the battery out, before working inside of the computer by pulling the tab shown to the left.
    • The battery can easily be removed.
  3. Dell XPS 15 Memory Replacement: passo 3, imagem 1 %32 Dell XPS 15 Memory Replacement: passo 3, imagem 2 %32 Dell XPS 15 Memory Replacement: passo 3, imagem 3 %32
    • You can see the big service lid, which is secured by three philips screws. The screws won't come out completely. The screw in the middle is a bit longer than the other ones.
    • After loosening the screws, the lid should stick out a few milimeters as shown in the second image.
    • You can now remove the lid with your finger. It will make some noise because the lid is also secured by some clips.
  4. Dell XPS 15 Memory Replacement: passo 4, imagem 1 %32 Dell XPS 15 Memory Replacement: passo 4, imagem 2 %32 Dell XPS 15 Memory Replacement: passo 4, imagem 3 %32
    • Inside you can see the two memory modules. There are two tabs on each side of each module. By pulling them away from the module, the module will jump out at a 45° angle as seen in the second image.
    • Now you can simply pull out the module and replace it. You have to remove the first module to get to the second one.
Conclusão
Uma outra pessoa concluiu este guia.
Clemens Harpf
Membro desde: 11/20/13
10 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 4,232
