Introdução
The SSD replacement only requires the removal of one phillips head screw. This is a very simple replacement, but it doesnt end after replacing the SSD. You may need to reinstall windows onto your Dell XPS.
O que você precisa
Find and remove the two .3cm torx head screws using a T5 screwdriver.
Find and remove the six Phillips head .3cm screws using a Phillips #0 screwdriver.
Find the single .3cm phillips head screw holding the SSD in place.
Remove the screw holding the SSD in place.
