Ir para o conteúdo principal
Dell XPS 15 L521X Hard Drive Replacement
O que você precisa
  1. Dell XPS 15 L521X Hard Drive  Replacement, Back Panel: passo 1, imagem 1 %32
    • Find and remove the two .3cm torx head screws using a T5 screwdriver.
    • Find and remove the six Phillips head .3cm screws using a Phillips #0 screwdriver.
  2. Dell XPS 15 L521X Hard Drive  Replacement: passo 2, imagem 1 %32
    • Unplug the battery indicator.
  3. Dell XPS 15 L521X Hard Drive  Replacement, Hard Drive: passo 3, imagem 1 %32
    • Find and remove the four .4cm phillips head screws holding the hard drive in place.
  4. Dell XPS 15 L521X Hard Drive  Replacement: passo 4, imagem 1 %32
    • Gently unplug and remove the hard drive
Conclusão
SHELDON SANTOS
Membro desde: 03/19/18
614 Reputação
Autoria de 6 guias
Equipe
Um comentário
This was a helpful tutorial, except for two small points. #1 - The yellow & red dots on step 1 are reversed; the T5 screws are the six along the two edges of the back panel and the P0 (Phillips #0) screws are under the face plate. #2 - the battery cable should ALWAYS be unplugged for component safety prior to doing any work on a laptop. An additional safety step (though optional) would be to physically remove the battery from the laptop prior to doing any work on it.
ICU Alex - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 1,113
