Introdução
In this guide you will be removing four screws and unplugging the hard drive. This is a quick easy replacement. You may also need to reinstall windows after completeing the hard drive replacement.
O que você precisa
Find and remove the two .3cm torx head screws using a T5 screwdriver.
Find and remove the six Phillips head .3cm screws using a Phillips #0 screwdriver.
Find and remove the four .4cm phillips head screws holding the hard drive in place.
Um comentário
This was a helpful tutorial, except for two small points. #1 - The yellow & red dots on step 1 are reversed; the T5 screws are the six along the two edges of the back panel and the P0 (Phillips #0) screws are under the face plate. #2 - the battery cable should ALWAYS be unplugged for component safety prior to doing any work on a laptop. An additional safety step (though optional) would be to physically remove the battery from the laptop prior to doing any work on it.
