Introdução
Changing the battery is pretty easy it only requires removing 6 screws and unplugging the battery. Be careful to not knick the wires to the right of the battery, if you keep this in mind this replacement will be quick and easy.
O que você precisa
Find and remove the two .3cm torx head screws using a T5 screwdriver.
Find and remove the six Phillips head .3cm screws using a Phillips #0 screwdriver.
Find the battery
Find and remove the 6 .4cm phillips head screws holding the battery in place
2 comentários
Hi, any recommendations on where to purchase a quality replacement battery?
Thanks
Highly doubtful you still looking for a battery 2 years later but I post my advice here for future fixers lol.
Sadly dell no longer sell the official battery, I recommend trying Amazon and if it doesn't work return it for a refund and try again.
Amazon has the best refund/return policy.
Don't trust eBay I had multiple batteries expand within minutes after powering on and I was left in the dust with no refund.
