Ir para o conteúdo principal
Dell XPS 15 L521X Battery Replacement
Guia arquivado
Este guia é mantido exclusivamente para fins históricos. Use a versão atualizada do guia para executar o reparo.
O que você precisa
  1. Dell XPS 15 L521X Battery Replacement, Turning Off the Computer, and Opening the System Badge: passo 1, imagem 1 %32
    • After turning off the computer, turn over the laptop and lift up the system badge (#2).
  2. Dell XPS 15 L521X Battery Replacement, Unscrewing the Base Cover: passo 2, imagem 1 %32
    • Unscrew the six Torx screws (#1) along the base cover's edge and the two Philips screws (#2) under the system badge.
  3. Dell XPS 15 L521X Battery Replacement, Pry Off Base Cover: passo 3, imagem 1 %32
    • Snap the system badge back into place so that it can be removed along with the base cover.
    • Using the spudger (or some other prying tool), pry the base cover away from the rest of the system.
  4. Dell XPS 15 L521X Battery Replacement, Battery Indicator Cable Removal: passo 4, imagem 1 %32
    • Remove the battery indicator cable (#3) from the white connector by lifting up the connector latch (#1) pulling on the tab (#2).
    • Even if you do not plan on replacing the base cover entirely, decoupling this fragile cable will ensure that it doesn't get damaged if the base cover is moved for whatever reason.
  5. Dell XPS 15 L521X Battery Replacement, Remove Battery: passo 5, imagem 1 %32
    • Disconnect the battery cable from the system board.
    • Remove the screws that secure the battery to the palm-rest assembly.
    • Lift the battery off the palm-rest assembly.
    • Turn the computer over and open the display as far as possible.
    • Hold the power button for about 5 seconds, so that the system becomes grounded.
Conclusão
Uma outra pessoa concluiu este guia.
Johnathan Hammond
Membro desde: 02/28/18
44.820 Reputação
Autoria de 408 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 130
