Ir para o conteúdo principal
Dell XPS 15 L521X Base Cover Replacement
Guia arquivado
Este guia é mantido exclusivamente para fins históricos. Use a versão atualizada do guia para executar o reparo.
O que você precisa
  1. Dell XPS 15 L521X Base Cover Replacement, Turning Off the Computer, and Opening the System Badge: passo 1, imagem 1 %32
    • After turning off the computer, turn over the laptop and lift up the system badge (#2).
  2. Dell XPS 15 L521X Base Cover Replacement, Unscrewing the Base Cover: passo 2, imagem 1 %32
    • Unscrew the six Torx screws (#1) along the base cover's edge and the two Philips screws (#2) under the system badge.
  3. Dell XPS 15 L521X Base Cover Replacement, Pry Off Base Cover: passo 3, imagem 1 %32
    • Snap the system badge back into place so that it can be removed along with the base cover.
    • Using the spudger (or some other prying tool), pry the base cover away from the rest of the system.
  4. Dell XPS 15 L521X Base Cover Replacement, Battery Indicator Cable Removal: passo 4, imagem 1 %32
    • Remove the battery indicator cable (#3) from the white connector by lifting up the connector latch (#1) pulling on the tab (#2).
    • Even if you do not plan on replacing the base cover entirely, decoupling this fragile cable will ensure that it doesn't get damaged if the base cover is moved for whatever reason.
Conclusão
To reassemble your device, follow these instructions in reverse order with the replacement component.
Uma outra pessoa concluiu este guia.
William Daniels
Membro desde: 04/06/18
824 Reputação
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 51
