Introdução
If you're experiencing issues with sound quality or no audio output from the speakers of your Dell XPS 15 9575 2-in-1 laptop, this guide will assist you in replacing the speakers.
The pair of speakers in your Dell XPS 15 9575 are responsible for producing audio output. Over time, they can degrade due to wear and tear or suffer damage from various factors, leading to distorted audio, crackling sounds, or complete silence.
Before proceeding with the replacement, it's important to diagnose the problem causing the audio issue accurately. If you're unsure about the root cause of the issue, it may be useful to download the Realtek High Definition Audio Driver on the Dell website before attempting to replace the hardware.
By following this guide, you'll be able to restore the audio functionality of your Dell XPS 15 9575 2-in-1 laptop and enjoy an optimal media experience once again.
Before you begin this repair, turn off your laptop and unplug it from the charging adapter.
O que você precisa
Use your T5 Torx driver to remove all eight 3.2 mm screws holding down the back panel.
Wedge an opening pick between the back cover and the base of the board, then slightly lift the tool to pop the clips on the back cover off.
Use the Phillips #0 screwdriver to remove all four silver 3.2 mm screws fastening the interconnect cable.
Use the Phillips #0 screwdriver to remove all eight 6.4 mm screws from the battery.
Use the Phillips #0 screwdriver to remove a single 1.7 mm screw securing each speaker.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
