Ir para o conteúdo principal
Dell XPS 15 9570 Wireless Card Replacement
O que você precisa
  1. Dell XPS 15 9570 Wireless Card Replacement, Base Cover: passo 1, imagem 1 %32
    • Make sure your device is powered off and unplugged before starting
    • Flip the device over so the base cover of the computer is facing upwards.
  2. Dell XPS 15 9570 Wireless Card Replacement: passo 2, imagem 1 %32 Dell XPS 15 9570 Wireless Card Replacement: passo 2, imagem 2 %32 Dell XPS 15 9570 Wireless Card Replacement: passo 2, imagem 3 %32
    • Using a Torx T5 screwdriver, remove the ten 3 mm screws on the back.
  3. Dell XPS 15 9570 Wireless Card Replacement: passo 3, imagem 1 %32 Dell XPS 15 9570 Wireless Card Replacement: passo 3, imagem 2 %32
    • Flip open the system badge and with a Phillips #00 screwdriver, remove the two 8.5 mm screws.
  4. Dell XPS 15 9570 Wireless Card Replacement: passo 4, imagem 1 %32
    • Lift the back cover off of the device.
  5. Dell XPS 15 9570 Wireless Card Replacement, Wireless Card: passo 5, imagem 1 %32 Dell XPS 15 9570 Wireless Card Replacement, Wireless Card: passo 5, imagem 2 %32
    • Using a Phillips #00 screwdriver, loosen the captive screw holding the wireless card bracket in place.
  6. Dell XPS 15 9570 Wireless Card Replacement: passo 6, imagem 1 %32
    • Lift the wireless card bracket off of the wireless card.
  7. Dell XPS 15 9570 Wireless Card Replacement: passo 7, imagem 1 %32 Dell XPS 15 9570 Wireless Card Replacement: passo 7, imagem 2 %32
    • Using a spudger, disconnect the coaxial antenna cables from the Wi-Fi card by popping them gently off.
  8. Dell XPS 15 9570 Wireless Card Replacement: passo 8, imagem 1 %32
    • Carefully remove the wireless card.
Conclusão
Uma outra pessoa concluiu este guia.
Margaret Combs
Membro desde: 09/08/21
504 Reputação
Autoria de 4 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 48
Duração total: 2,320
