Ir para o conteúdo principal
O que você precisa
Vídeo de Apresentação
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Dell XPS 15 9570, use o nosso manual de serviço.
    • Here's an unboxing of the device, followed by how to remove the battery and RAM from your 9570.
    It's basically a YouTube video
    BootlegScarce - Responder
IT FIX
Membro desde: 10/16/17
6.340 Reputação
Autoria de 74 guias
5 comentários
nice! if I have the fhd version of xps 15 9570, with 2X4gb ddr4 and 256ssd is it possible to change the battery from 56wh to 97wh?
orit2408 - Responder
Hm, good question, interesting which configuration you have, if it’s the same as mine so this is not a problem
IT FIX -
As far as I know that one has an option for an HDD, which uses up space where the 97wh is supposed to be.
Dennis van der Stelt -
I buyed directly from Dell the 97whr (product code 5XJ28 / GPM03 ) for my FHD 9570. I replaced without issues my 56wh removing the second hard drive box. Total cost: 76,58€ + 30,00€ shipping to Italy .
Massimiliano Monaro - Responder
Hi. Do you still have the old battery 56whr? Do you want sell it? I’m interested.
kurumadeiku@gmail.com
Jarek Musia -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 36
Duração total: 23,380
