Ir para o conteúdo principal
Dell XPS 15 9570 Speaker Replacement
O que você precisa
  1. Dell XPS 15 9570 Speaker Replacement, Base Cover: passo 1, imagem 1 %32
    • Make sure your device is powered off and unplugged before starting
    • Flip the device over so the base cover of the computer is facing upwards.
  2. Dell XPS 15 9570 Speaker Replacement: passo 2, imagem 1 %32 Dell XPS 15 9570 Speaker Replacement: passo 2, imagem 2 %32 Dell XPS 15 9570 Speaker Replacement: passo 2, imagem 3 %32
    • Using a Torx T5 screwdriver, remove the ten 3 mm screws on the back.
  3. Dell XPS 15 9570 Speaker Replacement: passo 3, imagem 1 %32 Dell XPS 15 9570 Speaker Replacement: passo 3, imagem 2 %32
    • Flip open the system badge and with a Phillips #00 screwdriver, remove the two 8.5 mm screws.
  4. Dell XPS 15 9570 Speaker Replacement: passo 4, imagem 1 %32
    • Lift the back cover off of the device.
  5. Dell XPS 15 9570 Speaker Replacement, Battery: passo 5, imagem 1 %32
    • Using the Phillips #00 screwdriver, remove the four 4 mm screws holding the battery in place.
    For laptops with the larger battery, there are actually 9 screws to remove.
    nebman227 - Responder
    My previous comment is incorrect, it is 7 screws, not 9, for the larger battery
    in the red circles wrong screws marked.
    Eugenio Rodriguez - Responder
    Is this 9570 model in previous guide you have 91wh and here you showing 56wh battery which is for xps15 9560 I will open myself mine before ordering replacement as your photos presenting model 60' not 70'
    Belliah - Responder
  6. Dell XPS 15 9570 Speaker Replacement: passo 6, imagem 1 %32
    • Use the iFixit opening tool to disconnect the battery connector from the motherboard.
  7. Dell XPS 15 9570 Speaker Replacement: passo 7, imagem 1 %32
    • With your hands, pick up and remove the battery from the system.
    Just right except my battery was full width.
    William Corwin - Responder
  8. Dell XPS 15 9570 Speaker Replacement, Speaker: passo 8, imagem 1 %32 Dell XPS 15 9570 Speaker Replacement, Speaker: passo 8, imagem 2 %32
    • Remove the speakers from the back of the computer.
    • Replace speakers with Dell 6GTPY 91 Wh Battery.
Conclusão
Amount of screws holding battery in place may vary.
Uma outra pessoa concluiu este guia.
Um comentário
Thank you for the tutorial!
Just did the swap with speakers form a DELL XPS 15 from an unknown model (most likely wasn't a 9570). Note that these speakers are common inbetween different XPS 15 models (at least XPS 9550 9560 M5510 9350 5520 5510 and Precision 5510 5520 5530 5540 PK23000RP00 TX47W 0TX47W) ******and can be interchanged.
The ones I just used were salvaged from an out-of-service XPS 15 but the parts can be sourced online easily (ex: https://www.amazon.com/Deal4GO-Speaker-R... )
Cheers
Antalog - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 12
Últimos 30 dias: 44
Ao todo: 2,432
