Ir para o conteúdo principal
Dell XPS 15 9570 Motherboard Replacement
O que você precisa
  1. Dell XPS 15 9570 Motherboard Replacement, Base Cover: passo 1, imagem 1 %32
    • Make sure your device is powered off and unplugged before starting
    • Flip the device over so the base cover of the computer is facing upwards.
  2. Dell XPS 15 9570 Motherboard Replacement: passo 2, imagem 1 %32 Dell XPS 15 9570 Motherboard Replacement: passo 2, imagem 2 %32 Dell XPS 15 9570 Motherboard Replacement: passo 2, imagem 3 %32
    • Using a Torx T5 screwdriver, remove the ten 3 mm screws on the back.
  3. Dell XPS 15 9570 Motherboard Replacement: passo 3, imagem 1 %32 Dell XPS 15 9570 Motherboard Replacement: passo 3, imagem 2 %32
    • Flip open the system badge and with a Phillips #00 screwdriver, remove the two 8.5 mm screws.
  4. Dell XPS 15 9570 Motherboard Replacement: passo 4, imagem 1 %32
    • Lift the back cover off of the device.
  5. Dell XPS 15 9570 Motherboard Replacement, Battery: passo 5, imagem 1 %32
    • Using the Phillips #00 screwdriver, remove the four 4 mm screws holding the battery in place.
  6. Dell XPS 15 9570 Motherboard Replacement: passo 6, imagem 1 %32
    • Use the iFixit opening tool to disconnect the battery connector from the motherboard.
  7. Dell XPS 15 9570 Motherboard Replacement: passo 7, imagem 1 %32
    • With your hands, pick up and remove the battery from the system.
  8. Dell XPS 15 9570 Motherboard Replacement, Heat Sink: passo 8, imagem 1 %32 Dell XPS 15 9570 Motherboard Replacement, Heat Sink: passo 8, imagem 2 %32
    • Use the Phillips #00 to remove the three (without graphics card) or four (with graphics card) 3 mm screws that connect the heat sink to the system board.
  9. Dell XPS 15 9570 Motherboard Replacement: passo 9, imagem 1 %32
    • Lift the heat sink from the device. The thermal paste may have dried and make this handling more complicated, be careful.
  10. Dell XPS 15 9570 Motherboard Replacement, Fan: passo 10, imagem 1 %32 Dell XPS 15 9570 Motherboard Replacement, Fan: passo 10, imagem 2 %32
    • Use the Phillips #00 screwdriver to remove the two 4 mm screws securing the grey display cable bracket.
  11. Dell XPS 15 9570 Motherboard Replacement: passo 11, imagem 1 %32
    • Using the Phillips #00 screwdriver, remove the 4 mm screw at the back right corner of the fan.
  12. Dell XPS 15 9570 Motherboard Replacement: passo 12, imagem 1 %32 Dell XPS 15 9570 Motherboard Replacement: passo 12, imagem 2 %32
    • Disconnect the fan cable on the left of the fan and on the right side from the RAM, using the opening tool.
  13. Dell XPS 15 9570 Motherboard Replacement: passo 13, imagem 1 %32
    • Lift the right fan off of the device.
    • Repeat steps 8-11 to remove the left fan from the system board.
    • The left fan is fixed with two 4 mm screws. Make sure you have removed them if the fan does not come off easily.
  14. Dell XPS 15 9570 Motherboard Replacement, RAM: passo 14, imagem 1 %32 Dell XPS 15 9570 Motherboard Replacement, RAM: passo 14, imagem 2 %32
    • Use your fingers to pinch down the metal tabs holding the RAM in place. Do this for each tab.
  15. Dell XPS 15 9570 Motherboard Replacement: passo 15, imagem 1 %32
    • Use your hands to carefully lift the RAM up and away from the tabs to safely take it out.
  16. Dell XPS 15 9570 Motherboard Replacement, SSD: passo 16, imagem 1 %32 Dell XPS 15 9570 Motherboard Replacement, SSD: passo 16, imagem 2 %32
    • Use the Phillips #00 screwdriver to remove the 5.5 mm screw next to the SSD.
  17. Dell XPS 15 9570 Motherboard Replacement: passo 17, imagem 1 %32 Dell XPS 15 9570 Motherboard Replacement: passo 17, imagem 2 %32
    • Using your hands, hold the SSD and slightly pull to the left.
  18. Dell XPS 15 9570 Motherboard Replacement, Wireless Card: passo 18, imagem 1 %32 Dell XPS 15 9570 Motherboard Replacement, Wireless Card: passo 18, imagem 2 %32
    • Using a Phillips #00 screwdriver, loosen the captive screw holding the wireless card bracket in place.
  19. Dell XPS 15 9570 Motherboard Replacement: passo 19, imagem 1 %32
    • Lift the wireless card bracket off of the wireless card.
  20. Dell XPS 15 9570 Motherboard Replacement: passo 20, imagem 1 %32 Dell XPS 15 9570 Motherboard Replacement: passo 20, imagem 2 %32
    • Using a spudger, disconnect the coaxial antenna cables from the Wi-Fi card by popping them gently off.
  21. Dell XPS 15 9570 Motherboard Replacement: passo 21, imagem 1 %32
    • Carefully remove the wireless card.
  22. Dell XPS 15 9570 Motherboard Replacement, Motherboard: passo 22, imagem 1 %32 Dell XPS 15 9570 Motherboard Replacement, Motherboard: passo 22, imagem 2 %32
    • Disconnect the two motherboard cables located on the bottom of the motherboard using the opening tool.
  23. Dell XPS 15 9570 Motherboard Replacement: passo 23, imagem 1 %32 Dell XPS 15 9570 Motherboard Replacement: passo 23, imagem 2 %32 Dell XPS 15 9570 Motherboard Replacement: passo 23, imagem 3 %32
    • Using a Phillips #0 screwdriver, remove the four 4mm screws securing the hard drive cover.
  24. Dell XPS 15 9570 Motherboard Replacement: passo 24, imagem 1 %32 Dell XPS 15 9570 Motherboard Replacement: passo 24, imagem 2 %32 Dell XPS 15 9570 Motherboard Replacement: passo 24, imagem 3 %32
    • Disconnect the two motherboard cables located on the right of the motherboard using the opening tool.
  25. Dell XPS 15 9570 Motherboard Replacement: passo 25, imagem 1 %32 Dell XPS 15 9570 Motherboard Replacement: passo 25, imagem 2 %32
    • Using a Phillips #0 screwdriver, unscrew the 4 remaining 4mm screws holding the motherboard in place.
    • Remove the motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
James Frederick
Membro desde: 11/09/23
109 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team 3-1, Harley Fall 2023 Membro de IUPUI, Team 3-1, Harley Fall 2023
IUPUI-HARLEY-F23S3G1
Membros da 4
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 12
Últimos 30 dias: 69
Duração total: 460
