Introdução
Use this guide to learn the steps to remove the keyboard of your Dell XPS 15 9570. The keyboard is an input device used to enter characters and functions into your computer system by pressing the keys.
Prior to starting this guide, be sure the laptop is powered off and it is unplugged from the charging cord.
O que você precisa
Using the Phillips #00 screwdriver, remove the four 4 mm screws holding the battery in place.
Use the Phillips #00 to remove the three (without graphics card) or four (with graphics card) 3 mm screws that connect the heat sink to the system board.
Use the Phillips #00 screwdriver to remove the two 4 mm screws securing the grey display cable bracket.
Use your fingers to pinch down the metal tabs holding the RAM in place. Do this for each tab.
Using a Phillips #00 screwdriver, loosen the captive screw holding the wireless card bracket in place.
Uma outra pessoa concluiu este guia.
